Old 09-11-2006, 01:43 PM
rickymix rickymix is offline
Default PT Launch Failure; \"Shared library error?\"
Hi y'all,
I just reluctantly re-installed OSX 10.3.9 in my G4 laptop.
Now ProTools won't open up! So I reinstalled v6.1 from my original CD.
(I had been running 6.2.2 before.) PT still won't boot. I get an
error message saying;
Application Launch Failure. The application Protools could not be
launched because of a shared library error: "A<Protools PPC dbg>
<Protools PPC dbg> <DAE> <Fic Set Overview Buffer>"
Any advice on how to proceed?
Thanks as always for sharing your expertise!
Cheers, Rick.
P.S. Should I download a newer version of P.T. or is 6.2.2 still OK? R.N.
Old 09-12-2006, 01:36 AM
mindnoise mindnoise is offline
Default Re: PT Launch Failure; \"Shared library error?\"
HI,
you need to download all the PTLE 6.4 updates. It´s free.
regs
last: PT11.3.1
Old 09-18-2006, 02:43 AM
Man, I've tried re-installing everything from the original 6.1 CD, then from the 6.4 upgrade which I downloaded from Digidesign, also tried 6.2.2 which used to run flawlessly, all with no success. I've trashed the DAE preferences in Library each time. The good news is that I'm no longer getting that "Library" error. What happens is ProTools starts loading up, starts loading the plug-ins, and when it gets to "Normalizing Gain Change" it crashes and there's an error message saying "The Application ProTools LE 6.4 has unexpectedly quit."
I'm on a 1.25Ghz PowerPC G4 laptop with 2GB SDRAM running a newly re-installed OS X v10.3.9. Airport and Bluetooth are "Off".
Any help would be greatly appreciated. I've ben down for over a week now!
Thanks, Rick Novak.
Old 09-18-2006, 11:53 AM
DigiTechSupt's Avatar
You should do a clean uninstall of every version of Pro Tools that you've had installed, then reinstall. After reinstalling, trash preferences before launching Pro Tools.
Avid Audio Tech Support
Support FAQ
Old 01-04-2007, 06:31 PM
Mix One Mix One is offline
What is meant by "trash preferences"? Trash which preferences?
Application Launch Failure - shared library error dlehrich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-26-2007 03:38 PM
Application launch Failure -- shared library error digimutt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-25-2007 10:20 PM
Shared Library Error on Launch sixlegcat Pro Tools TDM Systems (Mac) 1 07-06-2005 02:57 PM
Launch Failure "Shared Library Error" - help? rabbitears 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-09-2005 07:02 PM
shared library error on launch jg1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-10-2004 08:28 AM
