Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-01-2006, 08:28 AM
m2h2000 m2h2000 is offline
Default increasing H/W buffer size
I keep getting this error everytime i try to play back a mix.
It says "Operating System has held off interrupts for too long, If this occurs often, try increasing the buffer size In the playback engine dialog."
When I record it also displays the same error and prevents me from continuing recording.
Any tips will be helpful.
Thanks.
Old 01-01-2006, 12:59 PM
Slim Shady Slim Shady is offline
Default Re: increasing H/W buffer size
Did you try increasing the buffer size in the playback engine as the error suggested?
Also, please post your system specs, we can't help if we don't know what you're using.
Old 01-01-2006, 01:19 PM
Yes I increased the buffer size to the max it would go.
Specs:
Dual 864 Mhz - processor
512mb -memory
60gb - hard drive
100gb - external hard drive
MAC OSX 10.3.8 G4 - operating system
Old 01-02-2006, 11:29 AM
Amstrad_Attack Amstrad_Attack is offline
I get this same problem, and I have a Microsoft Windows XP. I turn it up as high as I can, but It wont stop popping that message up. I can't Select Bounce Disk either because it takes too long....Help me out. You will save my brain from exploding from annoyment.
Old 01-02-2006, 05:06 PM
What interface and version of PTLE are you using? Assuming they're compatible with your OS, have you done all the things in the "Setup & General Troubleshooting" thread near the top of the forum?
For the Windows XP guy, you should try posting over in the windows forums, I'm sure they have a "General Setup & Troubleshooting" thread over there too which would be worth your time to check out.
Advantages & disadvantages of increasing H/W Buffer Size? notr2d2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-16-2010 09:42 AM
Increasing Decreasing Buffer Size !!!! GuitarMessiah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-14-2010 12:24 AM
Popping and clicking . . . and yup, I tried increasing the buffer size NS3474 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-07-2010 10:38 PM
What can I do to get around Increasing the Buffer Size? tylersherrill7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-25-2008 12:21 AM
Increasing/Decreasing H/W Buffer Size... TylerJohnson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-20-2008 11:31 AM
