Anyone added ATA-66 card in G4 867/Mix Plus for add\'n IDE data drives?
A 12/01 thread quotes Charles McConathy of Promax as stating that installing an ATA-66 card will adequately support 2nd and 3rd hard drives in a G4. The built-in ATA-66 bus in my G4 867 already supports my (Master) system drive and one (Slave) data drive, so it can't handle any more.
Has anyone done this? My current data drive is IBM Deskstar GXP120 80GB 7200RPM, so I would probably just stay with IBM for the additional drives. Thanks, Mike |
Re: Anyone added ATA-66 card in G4 867/Mix Plus for add\'n IDE data drives?
yes, I have a 133 dual channel ata card internally in which i have two drives raided 0 together in my g4, it works great and the throughput is about 70 MB/s sustained.
I use seagate baracuda 60GB. The Seagates are supposed to be better for internal IDE ATA drives and IBM 60 GXPs are supposed to be better when used with firewire... but this the IBM/Seagate thing is all hearsay...I have not confirmed that....I'm sure either IBM or Seagate would be fine
Doug |
Doug,
Thanks. Some questions regarding RAID technology, since I have not used multiple data drives before. I just want to be sure I understand how it works. I would have three data drives: One on the built-in ATA-66 bus (along with the system drive), and two new drives on the new ATA-133 two channel RAID bus. (1) Using the RAID controller card, are data for a single ProTools sessionalways automatically split and stored on both drives on the bus? (2) When I later backup the data to my single external Firewire drive, will the data for a single session be consolidated back together into the backup session folder? (3) What happens if I assign my session data folder to the data drive on the built-in ATA-66 bus (rather than one of the two drives on the new ATA-133 bus)? Are the new drives ignored in this case, with all data going to the one "old" drive? Thanks again! Mike |
Please Help: New Avid PCIe Card added to old Core and Accell cards not working! | sterlingw | Pro Tools TDM Systems (Mac) | 24 | 12-05-2012 06:49 AM |
Added another PCIE card and Pro Tools lags! | gscoppa | Pro Tools TDM Systems (Mac) | 17 | 04-14-2011 02:50 PM |
PT crashes when drives added | gwok | Pro Tools TDM Systems (Mac) | 1 | 05-25-2010 10:26 AM |
Added HD Process Card but no activity | warbaby | Pro Tools TDM Systems (Mac) | 2 | 08-14-2008 06:46 AM |
Data Recovery from SCSI Drives??? | pnoise | Pro Tools TDM Systems (Mac) | 1 | 03-27-2001 08:07 AM |
