End-of-day process
What is the recommended 'end-of-day' S6 best practice?
My guess would be leave all power on but Shift-FADERS OFF to darken board/disable faders? I assume this increases the life of some components. |
Re: End-of-day process
The S6 MTM has a sleep mode where everything goes dark after a bit when nothing is active. Closing ProTools sessions and DADMan will remove any active faders. |
S6 sleeps displays and LEDs to save them and power. Generally speaking leaving electronics running (at the same temperature) prolongs life....but isn't very green
when leaving for the night, i always leave my S6 in "Screening Mode" (/Settings/System/Brightness/). then simply touch the MTM screen the next morning to wake it up.
Devin Emke Audio Post Production Saturday Night Live, NBC |
Screening Mode - which can also be triggered via SHIFT + Faders Off on the numeric section of the Automation Module. I agree with Eddie. My S6 is usually up for several months without a shutdown.
Jeff |
Thank you - I’m rarely the last or first to touch it and I’ve always done Shift-FADERS OFF and was curious if that was even needed.
Can not save "because the process is being used by another process". | luc-heuer | Pro Tools | 4 | 12-05-2021 01:51 PM |
RX4 Batch process | Reckless Erik | Post - Surround - Video | 24 | 09-11-2015 05:40 AM |
Problem populating HD 4 accel + Process + Process | Brandonx1 | Post - Surround - Video | 6 | 07-15-2010 04:40 PM |
hd process and accel process in same machine? | blumediaprojekt | Pro Tools TDM Systems (Mac) | 1 | 02-01-2006 07:51 PM |
Next Process after mix? | DaMixG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-19-2005 07:51 AM |
