S6 Workstation Connection Change
Just wanted to investigate this a bit further, having an issue with one playback rig. Open Pro Tools, Load up session, pull Workstation online on the S6, S6 M40 screen loads up tracks then WScontrol on the mac shows a message "WSControl connection change Disconnected from the system." No other machines are using the same IP as this one for our S6 control network. The current workaround is going into peripherals Ethernet controllers, untick eucon control surfaces press ok and then go back in and switch this back on. No other machines are doing this all running the same PT versions and seems to be happening overnight. Never saw this before updating to 2021.10. Specs; macOS Catalina Pro Tools 2021.10 Avid S6 2021.10 |
Re: S6 Workstation Connection Change
Greetings,
Can you please update to S6 2021.10.1 (bug fixes) and let us know if this is still happening? I presume you've shut down the system cold and brought it back up - and the same behavior is happening? Thanks. Jeff |
Tempted to leave this for now to avoid the risk of introducing any new issues with the console, would you happen to have a list of bug fixes in this version? I've been rebooting all systems but this seems to be a temporary fix. Thanks |
All of the current EUCON documentation can be found here ->
https://avid.secure.force.com/pkb/ar...Product-Guides And here's the What's New on EUCON 2021.10.1 -> https://resources.avid.com/SupportFi...leaseNotes.pdf best, Jeff |
This sounds like a network change on the Mac....WiFi connecting disconnecting, DHCP lease renewing, dodgy cable anything that causes a change in networking
Can't change buffer size, It is stuck in 512 and 1024. How can I do to change it? | Ariel Chimba | Pro Tools 12 | 9 | 12-23-2017 11:17 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Workstation Name letters & numbers, how do I change it? | Mike Thornton | Artist Series | 1 | 06-06-2012 09:36 AM |
Tempo change causing midi volume to change plugin output | tgrfox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-05-2011 01:08 PM |
Eleven Rack doesn't change sound output when I change to a new rig | Jlambton | Eleven Rack | 4 | 02-28-2011 11:51 PM |
