Realistic Drums (virtual)?
Ok here is a loaded question for you..
Can these drums sound like a real kit in a mix, afterall, they are samples from a real kit...?? Bascially im having tons of problems with them, still sound weak and non real in a full mix production. tried layering kits, layering snares, BD etc etc, tried busssing the drums through Parallel comp, still no good.. but the thing is I dont know exactly what it is thats missing.. Obv if budgets were limitless then a real drummer would be used of course. but its not and therfore we cant. - so we have to work with what we have here is a mix to give an example. http://soundcloud.com/and44/7-mix3 p.s Oh, I use oceanwaydrums. |
Re: Realistic Drums (virtual)?
They absolutely can sound great(and real) in a track. It comes down to a few things to really make it happen. #1 is likely laying out parts that a drummer would do. Thinking like a drummer really helps(remember things like that a drummer would not hit the hat and a crash at the same time). Getting consistent velocity so the hits sound like they were played by a drummer, paying attention to the song style. IOW, if its a rocking tune, you want the hits to sound like the drummer was playing hard, but a soft jazzy tune would call for lighter hits. Some folks are really good at "playing" the drum parts on a keyboard, but I prefer to play them in from a Roland TD10 kit(thanks to midi editing, even I can sound like i know how to play).
Then the mix may benefit from some normal drum mixing tips(I always split out the drums to individual tracks, whether I use SD2 or Addictive Drums). 2 tricks that help for me: I AUX send all the shell sounds to a stereo AUX track with a good compressor(I use Waves SSL compressor, but even BF76 will do). Moderate to heavy compression and mixing this track up behind the other drum tracks can fatten things up nicely. Then, instead of using the room sounds from the plugin kit, I AUX send all to another stereo AUX track and insert a reverb plugin with a short room sound(it just sounds better to me). I send little or no kick drum to that room 'verb. Using tricks like these can help make the drums sound like YOU recorded them, as opposed to you using the same plugin that another 100 people used. Play around with those ideas and you may find what works for you
sure I get you..
Honestly Ive tried so many things.. (not just on this mix) but we have 13 recorded.. and now im at that final mix stage but the drawback for me is the drums just dont sound "there" on any of them... In pro tools my "drums_buss" is bigger than anythign else, 3 BD's 2 Snrs' etc etc you get the idea.. layering drums liek no tommrow at times to get fullness where desired. Tried sending some to differnt AUX tracks, snare, toms and BD mostly, to give it some push&pull from compressers, tried transient control too to give more sustain or less attack, sending through multiverbs... ...I even had the midi file in PT, and render each part out one by one. (took forever) - of diffent ambience setups, and to mimic exactly liek you would get from a studio recorded kit with 8-12 mics+4 rooms natrually I treat them all with little EQ, comp and a bit of gain staging to help the "snap" but with all that said and done.. im still bitterly disapointed and really not sure what my next move really is.. The drums were played in from a TD9 and then just "humanised" and cleaned up. So I dunnno.. totally all out of ideas... I tried Addictive drums, the demo of Ezdrummer (didnt like it) - and Superior drummer is the same as EZ.. in that respect, so im confident the Oceanway drums are very very hard to beat. but yet, in my hands I guess not!. *sigh* please dont be shy.. lets hear your say! |
I have to wonder if maybe you are over-complicating it Seems to me that choosing one good kit and treating it appropriately should do the job Sometimes we have too many options
Now, I'm sure Oceanway drums are great, and it is a matter of personal preference. I use SD, and love it. Regarding the drum mix:
All the best!
ok, how would you tackle the snare?
give it a cut around 400-800 hz? or even boost it... for the attack would you use trans plugin? or simply overcompress on another buss? |
I don't use transient plugins. I usually use an 1176 to shape the sound, and sometimes a plugin with slower attack settings to let more of the transient through. McDSP has something called BITE, which essentially lets through more of the transients the higher the value. You could try parallel compression, but I generally don't "overcompress" anything. It just sucks the life out of the sound for me, and I don't like it. I use parallell compression to get more sustain and ambience, and to get more cymbal sizzle.
If you have good basic sounds recorded, check to see if Waves offers a demo of the JJP Signature drum plugin. It can work wonders!!! I just started experimenting with it and have been pretty knocked out by it
Thanks PT, some intersting comments
@Albee, JJP plugin crashes my PT for some odd reason, "just" that one aswell, all others are fine.. no idea as to why, runs fine under cubase. - i'll re-install them later and give it another shot, thanks for the heads up!. |
That's a bummer
what virtual drums to use for pt 7.3 | sonny7 | Virtual Instruments | 1 | 04-12-2012 06:18 PM |
Rolls on Addictive drums - TOO realistic in Demo - Listen to this clip | nicksorenson | Virtual Instruments | 8 | 05-29-2009 06:32 AM |
Virtual Drums | dead cat bounce | Pro Tools TDM Systems (Mac) | 8 | 09-01-2006 05:50 AM |
Virtual Drums | thenchel | Virtual Instruments | 8 | 07-25-2006 07:34 AM |
virtual drums | jc7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-24-2006 04:21 PM |
