Old 04-27-2011, 12:09 PM
Sleepover Sleepover is offline
Default Fader Pack thinks its a Main Unit
I recently unboxed a Pro Control Fader Pack and found that it thinks it's a Main Unit. I understand that this little expansion believes it's capable of bigger things, but it just does not have enough buttons to be a Main Unit.
Seriously, it's a fader pack that shows as a MAINUNIT if you check the system settings in the utility. I can only assume someone tweaked it so they could run 8 faders without a MAINUNIT being plugged in.
Anyone know how I can enlighten this poor misguided Fader Pack as to it's true role in this world?
Old 04-27-2011, 05:20 PM
SoundArts SoundArts is offline
Default Re: Fader Pack thinks its a Main Unit
Check and see if the cables to the meter led display are connected. If they are disconnected the fader pack will register as a main unit.
Disconnecting the cables are a simple hack to to use the fader pack without a main unit.
Good Luck!
Old 05-01-2011, 11:38 PM
mix109 mix109 is offline
All you have to do is change the name manually either from the Unit,or via the Peripherals/Ethernet Controllers Pane
I dont think that there is a Meter Led Display on the back of the Unit except(2) Com Ports (2)Midi Ports the Ethernet Connector and (2) 1/4 Jack Plugs
TRADE: ProControl Main Unit and 2 fader packs janmuths Buy & Sell 16 05-18-2015 01:15 AM
D-Command main unit, fader pack and X-mon the glass is half empty Buy & Sell 3 06-29-2013 02:41 PM
Main Unit and fader packs FOR TRADE janmuths ProControl, Control|24, Command|8 0 06-14-2012 09:56 PM
HELP! Edit Pack thinks its a Fader Pack! digitaltoast ProControl, Control|24, Command|8 1 01-27-2012 03:48 AM
Main control unit fader problem jackie ProControl, Control|24, Command|8 4 10-31-2007 09:30 AM
