Runnig SampleCell(s) on a separate Mac
I have heard that there is a way to connect SampleCell Cards on one computer into a MIDI configuration of another. In other words, running one's sequencer program on one Mac and being able to access the SampleCell cards in another Mac through some peculiar set-up.
How would one go about configuring it? Midi Manager? OMS? MIDI Config? Thanks in advance! |
Re: Runnig SampleCell(s) on a separate Mac
In a nutshell, you put a MIDI Interface on each computer and connect them with a MIDI cable, then configure OMS on each computer (one to send, the other to recieve).
Computer A = sequencer, Computer B = SampleCell(s): 1) Define Computer B as a device in your OMS Setup on Computer A. Enable all the MIDI channels you want the SC to respond to, it's multitimbral, it's not a Controller, and it doesn't support MIDI Time Code, MIDI Beat Clock, or MIDI Machine Control. 2) Computer B needs either a software app or a MIDI Interface that supports MIDI Patches to provide MIDI Thru to the SC. The SC Editor can provide MIDI Thru, but only on 1 channel at a time (all MIDI input gets channelized to the currently selected Instrument's channel). Pro Tools or a sequencer could be used to provide 16ch of MIDI Thru instead. Alternatively, a MIDI Interface that supports MIDI Patches with OMS (e.g. Studio 5) could be used. 3) Run a MIDI cable from Computer A's MIDI Interface output to Computer B's MIDI Interface input. If this too confusing (or not enough detail!), please let us know... Jeff Cohen Digidesign |
Runnig PT-LE 8.0.4cs2 and 9.0 on a Mac Pro. | tpthai2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-19-2011 05:56 AM |
PlugIn-recall of diff. setups-while runnig-Altiver | Ploch Klaus | Post - Surround - Video | 3 | 12-29-2003 04:33 AM |
Any one runnig NI studio collection with Mix | Valeri | Pro Tools TDM Systems (Mac) | 3 | 07-08-2003 12:48 AM |
Soft SampleCell not compatible with SampleCell 2 | P BUCKLE | Digidesign Hardware & Software | 13 | 06-08-2001 11:01 AM |
Samplecell in separate computer | SCJimmy | Digidesign Hardware & Software | 2 | 06-06-2000 10:44 AM |
