files make no sound and don't move meters when played in Pro Tools le
I am brand new to the forum thing. Please excuse my clumsiness.
No sound, no meter movement on 1 pro tools le session The session was fine. Then Pro Tools quit on me (which happens occasionally. Not unusual for me). When I reopened the session it looked exactly the same, but when I pushed play, although the cursor moved as usual, there was no sound and the meters didn't move at all (blank). The midi out did drive my midi device. I trashed the preferences and removed an unneeded file the session said was missing. I restarted it and it worked again... for awhile. A little later (an hour?) it jumped out again and when I reopened it the problem was back. Trashing the preferences did not work this time (I tried several times) Just this one session. Other sessions are normal. I have version 6.9.2 which has worked fine for many years now. Same computer...same software etc. Only this one session is giving me a problem (so far) |
Re: files make no sound and don't move meters when played in Pro Tools le
Help us Help You - READ THIS Before Posting! You might also want to post some screen shots of your mix window and I/O setup screen. Chris
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Thank you Chris.
And I will get my system info up by tomorrow. Track assignments are correct. It is as if the files are invisible to the session. No sound when soloed or not. No meter movement except on the midi channel. And, without making any changes within the session (I just trashed the preferences) It worked again for awhile, then after reopening the session, it didn't work again. Weird |
This probably shouldn't matter but I was changing the sustain on the midi file both times the problem happened.
Also, I went to earlier (back up) sessions. I even made a copy and opened that. None of these things worked.
Thanks |
What exactly does it do when it crashes? The error messages are "usually" a hint as to what the problem is.
Thanks RTman26
Pro Tools just quits...No warning...No error messages. This "suddenly quiting" is something that has been happening to me for many years. I just reload the session and continue on. Not a problem. However, I have never encountered this "silent files and non-moving meters" before. This session looks like all the other sessions but has this problem while none of the other sessions do. I have built a new session, and I am importing the audio files (that belong to the silent session) into it. So far so good. I just wish I knew what happened so that I can avoid it or fix it in the future. Thanks again for considering my problem. |
Manually played MIDI Notes arrive earlier than played. | SmokinBaldMonkey | macOS | 7 | 10-16-2019 06:47 AM |
Why legacy fade files should be played by PT10 | Postman | Post - Surround - Video | 5 | 12-06-2011 05:08 PM |
reason 2.5 w/ pro tools. no sound but the meters are jumping | chunkymutt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2007 07:15 AM |
Meters move, but there's no sound! | Styles Bitchly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-06-2002 08:11 AM |
meters move super slow | Blue Eyed Christ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-05-2000 11:40 PM |
