Old 10-11-2000, 04:26 PM
DaleB DaleB is offline
Default Blips in Bounced Files
When I bounce a mix to one of the hard drives attached to my Project II card, I get blips of audio from elsewhere in the file about 1.49 seconds apart lasting for maybe 100 milliseconds. When I bounce to my Mac startup drive, no blips. Lately, I've had a few warnings "There was an error on the Digidesign SCSI bus" or words to that effect. Anyone care to guess how I can fix this? (I'm using Pro Tools 4.3 on a Project II card, Mac OS 8.5.1)
Old 10-12-2000, 05:53 AM
DigiTechSupt's Avatar
Default Re: Blips in Bounced Files
Have you initialized the drive connected the Project card lately?
-I would suggest backing up and reinitializing the drive with a SCSI utility like FWB Hard Disk Toolkit. Restore the audio and session data to the drive and try the bounce again.
Brent
Avid Audio Tech Support
Support FAQ
Old 10-12-2000, 08:40 PM
I tried bouncing to TWO different drives (recently defragged) with the same result. Is the "error on Digidesign SCSI bus" warning a clue?
Old 10-13-2000, 06:13 AM
That error can indicate a problem with one (or more) of the following:
1- Bad Project card
2- Bad Project SCSI cable
3- Bad Drive
-For item 1, run DigiTest on the card. If it fails, then it is time to send the card in for repair.
-For item 2, if you know of anyone with a PT Project or Disk I/O system that is working, borrow their cable and see if that fixes the problem.
-For item 3, try a different drive altogether and see if the behavior persists.
Brent
Support FAQ
Pop at the end of bounced files brickroadstudio Pro Tools HDX & HD Native Systems (Mac) 11 07-25-2011 06:42 PM
Bounced files are distorted maddzaggz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 07-11-2009 02:49 PM
Bounced files end gets cut off breakie Pro Tools TDM Systems (Mac) 8 05-25-2005 01:26 PM
Bounced files shameeta General Discussion 4 11-09-2003 07:36 PM
bounced files have Garbage at end Mark Wheaton Pro Tools TDM Systems (Mac) 0 04-27-2001 05:22 PM
