Old 10-31-2006, 09:19 AM
donrey donrey is offline
Default 96k to 48k session conversion
Is there a way to convert a 96k session to either 48 or 44.1k, only changing the actual sample rate and maintaining the rest of the session intact? By this I mean, I'd like to keep plug ins/settings the same, but work at a lower sample rate so that I'm able to have more voices.
Old 10-31-2006, 09:51 AM
PhattBastard PhattBastard is offline
Default Re: 96k to 48k session conversion
My First thought would be to start a new session at 48k then import the old session data in and let PT convert the files during import. In the prefs make sure the file conversion process is set to the highest quality.
This is probably the fastest way to do this. I am curious to hear other people's opinions.
A side note. I believe that converting down from 96k should only be made down to 48k because it is simple math. I would let a mastering house do the final 48k to 44.1 k for a smoother conversion.
Phatt and Bastardy
Old 10-31-2006, 09:58 AM
Steve MacMillan Steve MacMillan is offline
I used to think that as well. What really happens during conversion is everything is upsampled to a common multiple, and then downsampled to the target samplerate. So as far as I can tell, converting from any sample rate to any other is a similar process with similar problems. The conversion process requires digital filtering and this is where the quality of the conversion is determined.
ProTools samplerate conversion is very good (in Tweakhead mode). If you are going for the ultimate in quality, you could consolidate all your audio from the top of the session and use Peak 5 to convert (very nice sounding conversion).
STeve
macmandigital.com
Old 10-31-2006, 10:17 AM
el Daniel el Daniel is offline
Go to Preferences and in the Editing tab select TweakHead in the Conversion Quality Options, then use "Save Copy In" from the File menu, and choose the sample rate you want to work.
Daniel.
Old 10-31-2006, 10:58 AM
jeff markham's Avatar
jeff markham jeff markham is offline
File->Save Copy In...
is the deal .. just choose a new sample rate and check the button
to copy audio.
since it's an even multiple, it's a straightforward (every other sample)
downsample.
jeff
to copy audio.
downsample.
jeff
Old 10-31-2006, 03:20 PM
Seeee Seeee is offline
downsample.
jeff
O'contraire Jeff.
I hope your ready for a long back and forth as to why not. I would of thought so too but apparently it isnt the case.
Pro Tools session conversion help! jv2612 macOS 2 02-03-2013 07:03 PM
Mac session to PC conversion? idkmybffjill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-20-2008 12:45 PM
Protools Session mp3 conversion. Zigo General Discussion 5 09-03-2007 11:02 AM
Session Conversion - Anyone in Calgary Alberta? blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-02-2007 12:18 PM
Mac/PC Session File Conversion!!! HELP! a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-24-2004 09:26 PM
