Old 01-03-2004, 08:49 PM
jpoprock jpoprock is offline
Default My iPod and PTLE 6.2.2 isn\'t playing nice
Maybe this is just the way it is... but if I mount my iPod first using 10.2.3 (yeah, I know it's not approved yet), then try to launch PTLE, it won't launch. It says that the firewire port is in use or something like that.
But if eject my iPod then launch PT, everything will be fine. Then I mount my iPod and I'm good to go. UNTIL i go to eject the iPod... as it won't let me. It says another program is accessing the device or something like that.
It's a major pain because I'll do a test mix, send it to my iPod, then take it to the car. And every time I do so... I have to close PTLE and Reason to eject the iPod. Then come back to my Mac, and have to launch PT and Reason all over again. It's very time consuming.
I did a search, and didn't really find much useful info. I found that Digi Database somehow puts files on your iPod, however, I've yet to see them. But I'm wondering if that is part of the problem?
Perhaps it's because Digi can't tell it's software to make the difference between and iPod and a regular FW HDD. It has to see it just like any other FW HDD. Maybe that's just the "obvious". Sorry.
Anyway, don't flame me for not searching.. or knowing the magic "search words" please. Can anyone make a suggestion??
Thanks!
Jason
Leo 10.5.7
PTLE 7.4.2, 002r, Micro
iMac G5 2.33ghz Core Duo Intel
OWC External FW HDD
http://www.soundclick.com/jasonsheroan
Old 01-03-2004, 09:59 PM
mixit mixit is offline
Default Re: My iPod and PTLE 6.2.2 isn\'t playing nice
I'm using OSX 10.3.2 and LE 6.2.2 and haven't had any problems using my iPod - firing it up, ejecting it, playing it via iTunes while PT is open, and putting bounced tracks onto it. . . it's all fine. I only have one firewire port on my iBook, so I'm daisy chaining first through my firewire drive, then through the 002 control surface and then to my iPod. Not sure how you're doing it - if you're using another firewire port or something. I don't know if this is any help to you - just letting you know that I haven't had any problems w/ my setup.
www.audioanalysts.com
Old 01-03-2004, 10:07 PM
I have two built in FW ports on my G4, and those are what I'm using.
j
Leo 10.5.7
OWC External FW HDD
Old 01-04-2004, 08:33 AM
Hmm. . . Have you tried coming out of the FW thru on your control surface to see if it plays nicer?
Old 01-04-2004, 10:58 AM
Keep in mind that I have an 002r, not an 002. I thought you were implying that I should plug my iPod into the extra FW port on the Digi... which does work just fine. But it does NOT work fine when the Digi is trying to run. It makes the 002r have buffer problems.
The bottom line is... Until Digi finds a way to tell the software to not access an iPod as a FW Drive, the iPod will always be 'in use" by the 002 as long as they are connected.
I'm shocked that no one else is reporting this problem.
j
Leo 10.5.7
OWC External FW HDD
PT 10 and Digi 003 not playing nice! Piers Gibbon macOS 16 01-21-2013 02:49 PM
Mbox3 on Win7 not playing nice with LE8.0.5 dsoundguy Tips & Tricks 1 12-14-2011 12:57 PM
PT 8.0.3cs2 and Redline Reverb not playing nice... ondruspat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-16-2011 07:31 PM
Akai MPK 49 and PT 7.3.1 aren't playing nice sircharles2 MIDI 2 06-24-2008 09:24 AM
Does anybody have PTLE7.0 playing nice with Sonar5 daveparker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-01-2006 11:29 AM
