I'm trying to use the MIDI functionality of PTLE to program drums. I use a Boss DR-770 drum unit. So far, I've been able to:
1. Select and play a drum pattern on the 770 and send the MIDI signals to be recorded on a PTLE midi track. 2. Play back the MIDI track by sending the MIDI data to the 770 and have it play the patterns. 3. Mess around the MIDI track to edit and modify the patterns, and change tempos. *Here is what I don't know how to do*: I would like to be able to send a MIDI signal from PTLE so that the 770 switches to the correct drum kit before starting to play the track. I would also like to be able to change the drum kit anywhere in the song. So is there a way to send a message from the PTLE sequencer to instruct the 770 to do that? I guess when I become more fluent with the 770, I'll probably be able to do other things, but this is my question for the moment. Help appreciated.
Digi002 Rack Mac Pro 8-core 3Ghz 8gb RAM 3X 500GB 7,200 SATA DRIVES OSX 10.5.7 PTLE 8.0cs3 |
![]() Quote:
Thanks. The MIDI Implementation documentation for my drum machine does not say anything about Controller 0 or Controller 32. Here's what it says:
------------------------------------------------ Status Second CnH ppH n=MIDI Channel No. 0H-FH(ch.1-ch.16) pp=Program Number 00H-7FH(prog.1-prog.128) ------------------------------------------------ I would like to use program number 09 at the beginning of the song, and change it to 25 in the middle. Does anyone understand how to relate this info to the Program and bank Change of PTLE (i.e. Controller 0 and Controller 32, and whatever else?) Thanks for the help
According to that I would say program 10 and 26...
Stephen Tyler |
OK. Got it to work. As it turns out, the DR-770 does not use banks. Sending a Program Change number directly does the change of drum kit that I wanted.
My next issue was to record and playback SysEx events. I tried dumping all the drum patterns from the drum machine into PT, following the instructions on p153 of the manual. Unfortunately, as soon as the dump begins (and PT correctly starts recording after the first note received as sson as I initiate the dump from the 770) no data actually gets recorded into PT, despite the fact that I can see on my Midiman LEDs that a lot of data is being sent. I set the MIDI filter to accept SysEx messages, but nothing gets recorded. Any ideas? Also, I find it pretty lame that PTLE does not allow to edit SysEx events, only record and playback. Is there a plugin that allows that? I'm starting to understand why people complain about the poor MIDI implementation of PT, although I'm new to this MIDI game.
Here's an interesting post I found by doing a Search on "sysex" in the Mac section:
In the meantime, it appears that using the Digi001 interface is the only means by which SysEx can get into Pro Tools. I will go ahead and report this behavior. Brent <hr /></blockquote><font size="2" face="Verdana, Arial">The Thread can be found here: DUC Sysex Thread I believe you may find valuable info by doing other searches of the DUC. See top of page for Search function. |
Syncing midi drum machine to RTAS Click Track | espada3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-11-2005 07:58 AM |
Sync drum machine to click track | espada3 | Pro Tools M-Powered (Win) | 0 | 08-09-2005 09:58 AM |
Midi to a drum machine | E-Buzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-31-2003 02:32 PM |
Drum machine with only MIDI in | MorryC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-31-2003 09:37 PM |
what do i need to do to track songs from a drum machine(mpc2000) to software. | nemesis | General Discussion | 1 | 05-08-2000 07:15 PM |
