#31
Virus check, firewall chek. I tried everything.
Diferents control. Like my cellphone, etc.
Motherboard Asus Rog Strix Z590 - Intel Core i9 11900K - 32 RAM DDR4 3200mhz HD SSD 1TB KINGSTON NV1 M2 / HD SSD 1TB SAMSUNG Windows 11 Pro NVidia GTX 980ti Protools 12,5 HD / Presonus IoStation 24c |
#32
It seems like I'm having a similar issue (although my apologies if this is more appropriate as a new thread). When I updated Eucontrol and Pro Tools to 2022.12 a lot of my track color switch assignments stopped working. I was able to re-map most of them by using a Eucon command rather than a key command (for example, instead of 'command +' to switch between the mix/edit windows - which previously worked - I just used the corresponding Eucon command).
However one command I haven't been able to get working is recalling a specific memory location. I always have marker 33 as a bounce selection, and previously had assigned it to a track color switch on the S1 as .33. (but using the 'insert special' /p....format). This doesn't work now though, any suggestions? If I assign the same button to a Eucon command (open system usage, for example) it works fine. Based on a previous comment I tried assigning a key command for Text Edit but that didn't work for me. I'm on macOS 13.2.1, Pro Tools 2022.12 (rosetta), Eucontrol 2022.12.0.81, Avid S1 (firmware: 21.8.1.0).
Mac mini M1, 16 GB RAM, Sequoia 15.1, Pro Tools 2024.10, Avid S1, UA Apollo Twin |
#33
Also note....uninstalling using the Windows method can cause issues. If you must uninstall then use the Installer and select remove all.
#34
![]() Quote:
It sounds like you have run into the Apple bug where Apps appear allowed in the accessibility settings but are actually not. This makes all keyboard shortcuts inoperable. Please manually remove EuControl and MClient and add back again to reenable. |
#35
Thanks so much Eddie, that did the trick! I see now that you mentioned this fix further up the thread, I must've missed it before. Always appreciate the help!
#36
Were they already in the list and you had to remove them....or did you just have to add them?
#37
They were there already (and toggled on), so I removed them and added them back.
What versions of Pro Tools 2022 work with Eucon 2022.9 | Mixmaster Rick | Pro Tools | 2 | 12-28-2022 01:13 PM |
Stacking EUCON commands in SoftKeys | StonehengeX | Avid S4/S6 | 5 | 09-28-2016 09:40 PM |
Eucon Softkeys Tech Talk | MCorbin | Avid S1, S3, Dock and Control App | 8 | 02-28-2016 01:17 AM |
Eucon Softkeys Tech Talk | MCorbin | Avid S4/S6 | 0 | 01-19-2016 08:43 AM |
Eucon Software - Editing, Setting Softkeys, Touch Screen Buttons-Pages | anason-records | Artist Series | 1 | 12-30-2014 08:22 AM |
