Old 02-14-2022, 06:57 AM
MiximusMaximus MiximusMaximus is offline
Default Audio tracks delayed
This is an odd one so I thought I would hit the collective knowledge here to see if anyone else has seen this issue.
I open a session to start mixing and everything is fine. After some time I notice that the bass and key parts are out starting to slide backward in time. To get everything back to normal, I go into the buffer size and change it from 1024 to 528 and back again, and it snaps things back...for a while.
The particulars of my set up are PT 2018.1 running on a MAC 5,1 12 core (3.46 processors) 128 gigs of RAM. The computer is interfacing via Lynx AES cards to a Mackie dxb. Everything is clocked to an Apogee Rosetta 200, files are 44.1k/24 bit.
I have had this setup for a bit and done quite a bit of work on this rig and this seems like a rather recent issue to pop up. Anyone else experience this oddity?
Old 02-14-2022, 09:25 AM
Default Re: Audio tracks delayed
Hmmm, 2 things come to my mind:
1-is your version of Pro Tools compatible with your version of OSX?
2-have you trashed prefs yet(always worth a try for odd behavior)?
Old 02-14-2022, 09:53 AM
I am running High Sierra 10.13.6 which is compatible, I neglected to mention that in the initial post. I have not tried trashing the preferences yet. I guess that is where I will go next. Thanks for the suggestion.
Old 02-14-2022, 12:36 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
I presume delay compensation is enabled?
Mac mini M2 base model, 16GB RAM. MacOS 13.2.1. PT Studio 2023.3.
Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Avid Control on iPad.
Old 02-15-2022, 11:24 AM
Yes, delay comp is on. Nothing is showing red. It's all very odd.
CPU spikes and delayed tracks with no plug ins T-Low Pro Tools 12 5 08-27-2016 11:11 AM
Tracks are 30ms delayed (Symphony I/O w/ LLM) kirkbross macOS 0 11-10-2014 07:09 PM
recorded tracks delayed by about 3k samples?!? theguru 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2006 01:27 PM
Audio Tracks Delayed in Playback Baughb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2003 10:43 PM
Delayed Recording w/ Multiple Tracks.. mjames08 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-09-2001 12:13 AM
