Old 10-01-2009, 10:16 PM
fooloof fooloof is offline
Default How to Automate the "Solo" button in PT8
I often like to drop out all of the tracks except for one or two (or sometimes drop them all out) for dramatic effect. The obvious and tedious way to do this is to mute all the tracks I don't want soloed. In PT 8 (not 7) there is an option for "s mute" in the automation enable pop up. This is the pop up that lets you choose which parameters will be active for automation. I assume that "s mute" stands for "solo mute." If this is correct, then can someone please tell me out to activate it? I tried pressing the "solo" button while writing automation, but it did not record it. I was not able to locate this information in the reference guide or in post archives.
Thanks a lot for the help.
Old 10-01-2009, 10:29 PM
barlevy barlevy is offline
Default Re: How to Automate the "Solo" button in PT8
s mute stand for "sends mute"
since solo is a function made for checking something on a channel
and not for mix - it can't me automated.
if u still want to automate solo u need to select all OTHER tracks make a group out of them and then auto mute them
Old 10-01-2009, 11:36 PM
JonesH JonesH is offline
I'd use the "All tracks" group, make the automation and then diable the group and remove the muting from the channels you want to hear.
I just wanna do engineering...
(as opposed to make music :/ )
Old 10-02-2009, 10:52 AM
Exactly
EuCon command for old Command8 "Plug In" window button? myhrik Pro Tools TDM Systems (Mac) 6 06-21-2013 03:48 AM
MBox "launch control panel" button not working again with the latest driver Zarabozo Windows 0 10-26-2012 12:01 AM
Mute / Solo "Shift +" shortcuts don't work kaiserpathos macOS 2 08-14-2011 10:39 PM
Why is my "Midi Merge" button grey? I don't have the option to press it. Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-19-2009 05:57 PM
problems on "solo" button and cabling SHIRLEYL Tips & Tricks 2 01-31-2002 06:15 AM
