Old 10-03-2008, 08:17 AM
Fritz12534 Fritz12534 is offline
Default Newly recorded tracks delayed behind the beat
I was in the middle of a session yesterday and had recorded about 7 vocal tracks over rhythm tracks, at 108 bpm. Everything was fine, and then the next vocal track recorded, although sounded fine while recording and monitoring through headphones, played back a fraction of a second behind the tempo. Low latency monitoring mode was engaged. I hadn't changed any other setting that I know of. I tested it again by recording just quarter note claps through the microphone and again, sounded fine while recording, but plays back delayed. I opened a new session and tested it there and it is fine, so whatever the issue is, it's particular to that session. Any ideas?
002R
PT 6.4
MacG5 1.6GHz, 3G RAM
Mac OS 10.3.9
Old 10-03-2008, 08:56 PM
Default Re: Newly recorded tracks delayed behind the beat
Whenever PT gets weird, trashing prefs often helps. Or close and reopen Protools.
Old 10-03-2008, 09:31 PM
Krumbz Krumbz is offline
002R
PT 6.4
Mac OS 10.3.9
Have you checked the latency/delay on each track? Do you have any plug ins that incur latency/delay inserted into any track?
My Pro Tools isn't open right now but I think the key command is Apple+click on the volume in the channel to switch from volume to pan to delay.
Old 10-04-2008, 09:49 AM
Jason1 Jason1 is offline
I would also trash the Digidesign database folder on the record volume. I remember having this same problem somewhere around v6.4... You may want to consider an update in your future.
Old 10-06-2008, 11:51 AM
Thanks! I'll check these suggestions out! Really appreciate it! Yes, and an upgrade for both PT and Mac OS, which I'm running 10.3.9. Sounds like OS 10.5 and PT 8 are both around the corner
Fritz
Audio on newly recorded tracks is out of sync lectrohowie macOS 0 04-09-2012 08:12 PM
Newly recorded tracks play out of sync Kourquie Pro Tools TDM Systems (Mac) 1 07-13-2009 04:57 PM
recorded tracks delayed by about 3k samples?!? theguru 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2006 01:27 PM
Can't play back newly recorded tracks trion12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-01-2005 12:05 AM
Newly recorded audio, here a minute, GONE the next storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-30-2003 01:23 PM
