Old 04-07-2008, 12:09 AM
zion72 zion72 is offline
Default Will my new laptop work with pro tools 7.4?
I have installed version 7.4 but it wont run smoothly. It's very slow and has crashed several times.
Hers my specs.
Center dv9675eo Entertainment - Core 2 Duo T7250 2 GHz - 17" TFT
Intel Centrino Duo
Prosessor Intel Core 2 Duo T7250 / 2 GHz ( Dual-Core )
Cache-minne 2 MB - L2 Cache
RAM 2 GB (installert) / 4 GB (maks.) - DDR II SDRAM ( 2 x 1 GB )
Harddisk 160 GB - Serial ATA-150 - 5400 opm
Harddisk (nr. 2) 160 GB - Serial ATA-150 - 5400 opm
Optisk lagring DVD±RW (+R DL) / DVD-RAM / HD DVD-ROM
Skjerm 17" TFT 1440 x 900 ( WXGA+ )
Grafikk-kontroller NVIDIA GeForce 8600M GS - 256 MB
Operativsystem Microsoft Windows Vista Home Premium
Old 04-07-2008, 08:43 AM
cruisemates cruisemates is offline
Default Re: Will my new laptop work with pro tools 7.4?
Are you using an external harddrive for your music files? Only the program files should be on your laptop, all you data (when you create a song) should run from an outboard hard drive, firewire connected if possible, no less than USB-2.
- but the second mouse gets the cheese
Old 04-07-2008, 12:24 PM
Do I need to run Audio files on an external harddrive even if my laptop have 2 harddrives?
I only have audio files from pro tools on the second hard drive. Or is it something with the laptops specs that dont match with pro tools.
Old 04-07-2008, 12:28 PM
spkguitar's Avatar
Your second drive is too slow. It needs to be 7200rpm or faster.
You could try to replace one of the internal ones with a faster one, or use an external firewire drive.
Old 04-07-2008, 01:24 PM
Upperesh Upperesh is offline
What kind of motherboard?
Old 04-07-2008, 11:14 PM
My girlfriends laptop is also a hp with centrino duo pros 1,8ghz and only 1 gb ram. Proo tools runs smoothly with both program and audio on the same disk 5400rpm. It runs on xp media center edition and works great. My new pc with higher specs have big trouble running pro tools.
When I got the laptop I downloaded all available upgrades for vista, I looked at digidesign and saw that sp1 is'nt compatible. I dont know it If I have upgraded to sp1 or if sp1 is available yet?
Old 04-08-2008, 02:11 PM
Ok, I have now tried an external hard drive with 7200rpm and same result. It runs great for about one minute and then it slows down and get realy slow. Sometimes when I open a new song it peaks and makes a load noise, I then have to close pro tools and restart. Can it just be vista home premium, should I install xp pro?
What new laptop/computer will work with Pro Tools 8? ha sma5jp Getting Started 1 12-28-2013 02:23 PM
Will my laptop work with Mbox + Pro Tools Essentials? dukenewcomb Pro Tools SE and Essential (Win) 0 01-28-2013 11:58 AM
Pro Tools M-Powered - Will it work on my laptop? bob081191 Pro Tools M-Powered (Win) 3 08-13-2010 05:04 PM
Will Pro Tools 8 m-powered work on my laptop? jjk Pro Tools M-Powered (Win) 9 05-28-2010 02:43 PM
Pro-Tools LE 7.3 on an IBM X31 Laptop? Will it work? HELP!! epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-13-2007 03:48 AM
