Old 02-21-2008, 04:54 AM
studiokeyz studiokeyz is offline
Default midi/audio overdub
I'm trying to overdub in midi and audio. I'm using PT 7.3 @ home on my laptop and @ my studio, when I select the transport window and enter 1 in the pre roll box it goes to the start of the song no matter what marker I select. Say I select 5:00 and want to overdub around here it will go to the beginning of the song then when it gets to the 5:00 it'll start the overdubbing. Why is it doing this? Am I missing an option?
Old 02-21-2008, 05:18 AM
andrewSF andrewSF is offline
Default Re: midi/audio overdub
You do have "Link Timeline and Edit Selection" turned on, right? Are things working normally except when you've got the pre-roll turned on?
My first thought was that you might be selecting pre-roll of an hour rather than a minute, but that would only be possible if you were using time code for your main counter. Do you happen to have the DV Toolkit?
Old 02-21-2008, 10:58 AM
yes link timeline and edit selection are on. i dont have the dv toolkit, im just trying to see why is it doing this, it used to work fine. I know its probably one small option i have set but i cant find what exactly it is.
Old 02-21-2008, 12:36 PM
The Dougfather The Dougfather is offline
So you want a 5 minute pre -roll?
Click on the time section of the transport and change the drop down menu to bars, 4 bar pre roll will then read something like 5/00/00 not 5:00.
Also make sure you selecting the area you want to overdub and not just dumping the cursor and then hitting record in a single spot.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
midi overdub with pt? kalony Tips & Tricks 4 08-12-2008 05:27 PM
MIDI Overdub? tabnetic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-30-2006 08:24 AM
midi playback and overdub audio porkipine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-24-2005 07:15 PM
How do i overdub an AUDIO track??? Mactronix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-29-2002 02:43 PM
How do i overdub a midi track? Mactronix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-28-2002 11:29 AM
