Old 10-04-2006, 07:09 AM
colin1 colin1 is offline
Default Adding accel card to existing system
I am trying to add an accel card to an existing system. the systwm I am adding to has a core card with 2 hd engines, and one eccel card. When I put another accel card in the system at the end of the chain, here were my problems.
New sessions worked great, card was recognized right away. When I loaded old sessions, everything is there, but all tracks routed to busses were distorting badly. as soon as I routed them to outputs instead busses. distortion cleaned up. I am trying to finish a mix that is already started, and do not wish to start from scratch with it. If anyone has suggestions or has had this happen to them please let me know. Thanks
Old 10-04-2006, 09:42 AM
jre3132 jre3132 is offline
Default Re: Adding accel card to existing system
did you run digitest after you installed the new card?
If not, make sure you turn your monitors down before you start it...
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 10-04-2006, 11:23 PM
Andre Knecht Andre Knecht is offline
The correct order for Digi cards is:
Core
Accel
Process
Make sure to read your “Getting Started With ProTools” documents.
Also, I recommend that you trash your “DigiSetup” file after the installation.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Adding another Accel card ? jackp Pro Tools TDM Systems (Mac) 8 10-28-2012 09:25 PM
Help-adding first PCI Accel card to pre-existing PCI HD3 system Armando Pro Tools TDM Systems (Mac) 4 05-09-2012 04:49 PM
Will adding an Accel card to an HD3 system give me more voices? WildHoney Pro Tools TDM Systems (Mac) 2 03-02-2011 05:30 PM
Adding another Accel card Dusan Pro Tools TDM Systems (Win) 4 02-18-2010 04:05 PM
adding an accel card to an HD3 system Brad Ryan Pro Tools TDM Systems (Mac) 2 09-13-2005 02:57 PM
