Old 12-30-2004, 08:33 PM
One Track Music One Track Music is offline
Default 6.7 Audio Tick Track Loses Automation on Trim
Had this verified by Digi. Has this already been discussed? Take a region, change volume of the whole region. Trimming either the start or end of the region loses that breakpoint and ruins the volume. Changing the track to "sample based" doesn't help in my case. Fairly major bug. Any thoughts?
Thanks,
Joel
G5 DP 2.5 HD 2 Accel 6.7cs5 OSX 10.2.5
www.joeldouek.com
"Show me your Pasodoble!"
Old 12-31-2004, 11:31 AM
Default Re: 6.7 Audio Tick Track Loses Automation on Trim
Bumping
www.joeldouek.com
Old 12-31-2004, 03:36 PM
SessionKat SessionKat is offline
You're using the Trim tool? Or dragging top/end breakpoints with Grabber?
what does "ruin volume" mean?
Thanks,
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old 12-31-2004, 06:09 PM
Sorry I should have expressed myself better:
1. Select an audio region on a tick audio track by double clicking in it.
2. Switch to volume view and using the trimmer tool reduce the volume of the region in one go. This way the two volume breakpoints, front & end, are now "embedded" in the region, and if the region is moved, copied etc, the volume automation comes with it. That part we all know.
3. OK so now put it back to waveform view, and using the trimmer tool, change the length of the region, either from its beginning or end.
4. Now check what happened to the volume change you made before: depending on whether you trimmed the beginning or end of the region, the beginning or end volume breakpoint is back at zero, giving you a diagonal line instead of a horizontal line.
Thanks,
Joel
www.joeldouek.com
Old 01-02-2005, 10:59 AM
Looking from some feedback & an estimated bug fix cs if this has been discussed.
Thanks,
Joel
www.joeldouek.com
Old 01-02-2005, 02:01 PM
crizdee's Avatar
crizdee crizdee is offline
Hello,
I have just checked this with my 6.7LE system and it is working fine here! if i change the selection length in samples mode the breakpoint moves with the selection edit, if i change the selection length in tick mode it creates a new breakpoint from the selection boundary and also leaves the original breakpoint in place. I'll check this tomorrow on my HD system 6.7.
Regards
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-03-2005, 12:18 PM
I see the bug as Joel describes.
Investigating........
-tv
Tim vdB
Avid Audio
Old 01-03-2005, 10:18 PM
Thanks Tim - looking like a TDM thing then.
Joel
www.joeldouek.com
Old 01-03-2005, 10:21 PM
...and thanks Chris from Brighton (Londoner myself (in NYC)) - let us know what you find.
www.joeldouek.com
Old 01-04-2005, 12:47 PM
crizdee's Avatar
Hello again,
Yes, it seems to be TDM in tick mode!! all seems fine in samples mode!!!
I'll double check in LE again later on my laptop!?
Regards
Chris
Producer, Engineer,
www.ukmastering.com
Copy Audio Track Automation to Midi track controller (Mod Wheel) cybercampbell macOS 3 05-11-2013 10:18 AM
MIDI Automation to Audio Track Automation BBKBB Pro Tools 10 6 11-28-2012 01:56 PM
Trim Out Regions By Defined Amount/Import Audio To Single Track pfo Tips & Tricks 3 03-18-2010 08:51 AM
overall automation trim on track,possible? b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2006 06:06 PM
digi 002 rack - tick, tick, tick, tick, tick osset 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-20-2003 04:20 PM
