Old 03-14-2009, 03:15 PM
Tbassist4 Tbassist4 is offline
Default Major comp. problem - considering reverting to 002 rack instead 003 rack, good move?
Here's a short summary of the problem I'm having:
Macbook Pro 17" 2.4 Ghz Core 2 Duo
Digi 003 Rackmount
Whenever I initiate Digi Coreaudio or Pro Tools, a high pitched ringing or tone starts to come from the left side of my Macbook Pro. It is not in the signal, and it is not related to a bad ground. The sound comes from the Intel Core 2 Duo processor in my Macbook Pro. Programs like QuietMBP and changing system files do nothing, and they are dangerous. I've talked with Digidesign and they've confirmed the problem to be with my computer and not the 003 rack. I've tried it with other Macbook Pros and the ringing does not occur. I've also tried other 003 racks with my same computer and the ringing still occurs.
I've been to the Apple Store about 4 or 5 times. They've replaced the logic board and left I/O board in my MBP.
Here's where the difficulty comes in. I called Apple tech support, and they told me I could send in my Macbook Pro. However, they said they would keep it there until they figure out what's wrong. This is potentially great, but they didn't say how long that could be or if they knew what the problem was at all. I would also be missing my main computer for the entire duration.
In lieu of this, I'm considering changing my audio setup all together. I've heard nothing but great things about 002 racks. Would I really be losing all that much if I went for a trade in of my 003 rack for a 002 rack? If you were in this situation, would you send your computer in, or would you change your audio setup?
Old 03-15-2009, 12:21 PM
ladewd ladewd is offline
Default Re: Major comp. problem - considering reverting to 002 rack instead 003 rack, good mo
My son's Macbook had to go back to the factory for repair. I took it to the Apple store and it came back within a week. Apple service is very fast. They'll probably just replace everything if they can't figure the problem out.
Have you used an 002 before with your computer? My guess is you'll still wind up having problems if the problem is with your mac.
CA
Old 03-15-2009, 12:32 PM
flommer flommer is offline
Yes, what makes you think a 002 will fix the problem?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 03-15-2009, 04:20 PM
Ken Burk Ken Burk is offline
Any LE setup is going to be host-based, so unless you get your computer fixed, it will probably continue to occur. Better to get it fixed now with a little hassle while under warranty.
MacBook Pro 2.5GHz
Digi 003 Factory / MBox2 Micro
4 GB memory, OWC 750GB HD
OSX 10.5.5, PTLE 8
Eleven Rack and G major 2: help! (FX loop) Schromeo Eleven Rack 5 01-07-2014 12:24 PM
003 rack comp build. Need some info... geekkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-18-2010 02:32 PM
BIG, MAJOR PROBLEM i7 comp gurus plz help! HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-16-2010 03:12 AM
thinking to move from 002 Rack to 003 Factory akhafaji 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-12-2009 07:50 AM
bought new comp with 002 rack always crashing dunkyj Pro Tools TDM Systems (Win) 3 11-07-2005 10:31 AM
