Could not complete the Import Audio
Could not complete the Import Audio command because Assertion in "/Volumes/Development/183141/ProTools/NewFileLibs/Cfd/MacOS/Cfd_ImportAudioDialogMacOS.mm" ,line 603
what do i do to fix this problem ? |
Re: Could not complete the Import Audio
Welcome to the community.
Start with trashing Pro Tools preferences and see if that fixes it.
No way anyone can help unless you provide more info; OS, PT version, drive configuration, machine configuration, etc...
That said, try this: http://petegates.com/pg-pt-prefs.html
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Not sure what you mean by trashing Pro Tools preferences ? Can you give me step by step what to do please ?
The link that Peter provides gives you a utility that for trashing prefs that is easier than doing it by hand, but you should take the time to understand what that utility is doing. If that does not work come back here with additional information and a clear description of what you have tried. Including importantly what exact format file you are trying to import. And what else you've tried after trashing prefs... like testing the import from a a new empty session. |
Hope this would help...! Sent from my SM-A910F using Tapatalk |
Was this ever resolved? Does anyone know how to fix it? I am getting the same error message when I try to import audio.
System details: iMac (Retina 5K, 27-inch, Late 2015) High Sierra 10.13.3 Pro Tools 12.5.2 Tried trashing prefs and restarting computer and neither helped. |
Same issue on my computer having completed an update to High Sierra. The error message reads:
Could not complete the Import Audio command because Assertion in "/Volumes/Development/151228/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 575. (Use the Copy button to copy this message to the clipboard.) Tried zapping the P-RAM, didn't work Thanks |
Could not complete the Import Audio command because Assertion in "/Volumes/Developmen | awodzanowski | Pro Tools 11 | 2 | 03-22-2016 12:40 PM |
Cannot complete audio import command | Engine Room | Pro Tools 11 | 1 | 01-19-2016 06:01 PM |
Could not complete import audio... | sjbruce | Pro Tools 11 | 4 | 10-06-2015 04:00 PM |
Could not complete the Import Audio command because magic ID does not match | ronfinch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-21-2010 02:32 PM |
Error: "pro tools could not complete the import audio command because assertion in" | elsterNJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-15-2009 09:38 AM |
