Old 09-18-2021, 02:26 AM
darkwavo darkwavo is offline
Default Carbon- Basic Questions..
Cheers y’all ,
I got a Carbon a few weeks ago and I am loving it…sounds great and the lightning bolt low latency makes it the only way for me (other than HDX) for tracking.
I have a few technical questions:
1. Parallel hardware inserts… if I bus a track out to a compressor (for example) and return that on another audio track,,, must I engage the lightning ⚡️ bolt on both tracks or just the compressor track (record enabled) to obtain phase coherent alignment ???
2. If I were to add say Merging Hapi via ADAT to expand my I/O by 8 in and out …. Would it function the same as Carbon regarding the lightning ⚡️ bold mode and low latency performance?
3. I must use a DB25 input to bypass the line/mic amps in Carbon? What software setting needs to be changed to bypass Carbon amps?
Thanks and appreciate the help!!
Old 09-18-2021, 06:44 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Carbon- Basic Questions..
Originally Posted by darkwavo View Post
Cheers y’all ,
Here is what I do
#1 ....I run my 2 outboard hardware FX units as Hardware I/O "Inserts" (see my session Mix window below), I do not "Bus out" to them, and when using them parallel, I place them on Aux Input tracks, not audio tracks . And since I send to them from audio tracks that I have put into DSP mode, (and they are associated downstream tracks) they automatically get put into DSP mode
#2 Don't run any ADAT so can't comment from personal experience .... But I am guessing yes .. I know a small studio owner who has Carbon and I think uses ADAT so I will ask him
#3 Yes very easy launch PT > Setup > Hardware > Line I/O tab. (see mine below)
I use 1-4 for microphones thru Carbons pre amps and then 5-8 Bypassed for my two 2 channel Hardware units ,, a Comp and a Reverb . (also note) If you have not done it ? I suggest google "Avid Carbon User Manual" and down load it . It's the best manual Avid has put out..
Here my two hardware units are on Aux Input tracks righthand side labeled M7 (reverb) and 2 Mix (with my Comp on it) which is my entire session 2 Bus
Orange arrow showing sending from my Acoustic Rhythm Guitar -Routing Folder track, to my Reverb track
System :
Avid Carbon interface , PT Ultimate 2021.6 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Catalina 10.15.7
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 09-18-2021, 08:09 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Originally Posted by K Roche View Post
Here is what I do
Here my two hardware units are on Aux Input tracks righthand side labeled M7 (reverb) and 2 Mix which is my session 2 Bus
I would like to see the pictures but they don't appear. Could you please re-upload the pictures?
What is more relaxing then Music?
GigabyteZ490 Vision D
Xeon Core I9 10850K cpu Windows10 v.20H2
Avid HDX 2021.7 Ultimate - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - AVID Artist Mix (2)
Universal Audio UAD2 Pci-E and Satellite USB Octo - Pci-E Quad - SOLO 610 - Twin-finity
Antelope Trinity - 10M
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 09-18-2021, 08:38 AM
K Roche's Avatar
Humm They are Imgur BBC code images (but they are PNG) and should be showing I wonder if it is your browser I just re did them
see if these url links work
If not here are the Direct links but you will have to open them
https://i.imgur.com/yxo3om8l.png
https://i.imgur.com/rP3y9qIl.png
System :
Enjoy the Journey
.... Kev...
Old 09-18-2021, 08:52 AM
abc1mce2's Avatar
Yes I can see them now. Thank you.
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 09-18-2021, 08:54 AM
K Roche's Avatar
OK to clarify the reposted [img] s in my original are open for you ? OR. the Url ' images are open for you,, or you have to click the direct links
Ha I see you also have M7's also I pretty much do not use plugin reverb any more
System :
Enjoy the Journey
.... Kev...
Old 09-18-2021, 09:03 AM
abc1mce2's Avatar
I still use plugin reverbs but the M7 is by far better than my plugins. I said that to say this, usually with electronic and hip hop plugin reverbs is all I need. I realize that depending upon the source material (song) that a pretty reverb (M7) is not always required. Instead of a second M7 I wish I had a 480L.
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 09-18-2021, 03:21 PM
Here is what I do
Thanks for the great explanation. Are you putting the tracks assigned to the reverb /comp into DSP mode to keep the hardware insert latency correct ?
Thanks again !
Old 09-18-2021, 05:40 PM
K Roche's Avatar
Thanks again !
Not sure what you mean by "tracks assigned to reverb/comp",,,,
Let me explain a bit further and see if I can clarify better
I have four folder tracks all routed to the 2 Mix track ( which has my Comp on it and is labeled 3 U in the inserts section ) The folder tracks are A Rhy Gtr -- A Ld Gtr --E Ld Gtr and the Vox
Right now only the A Rhy Gtr Folder track is opened up and showing the two mono audio tracks routed to it = A Rhy Gtr L (for Left) and A Rhy Gtr R (for Right)
So
Starting from left side is the Stereo - A Rhy Gtr folder track (acoustic rhythm guitar ) then -- two mono audio tracks -A Rhy Gtr L and A Rhy Gtr R which are routed to the A Rhy Gtr folder track,,, which is routed to the 2 Mix track ---- and I am also sending (labeled M7 in the sends section) from the A Rhy Gtr Folder track to the M7 (reverb track). make sense so far ?
Ok so when I clicked the DSP mode on either one of the A Rhy Gtr- L or R tracks,,, then the A Rhy Gtr folder track, and the 2 Mix track, and the M7 track and the Master Fader track (because the 2 Mix track is routed to it via Stereo Mon. (which is what I label my main 1 &2 outs) they all automatically went into DSP mode ( i.e all of the downstream associated tracks )
System :
Enjoy the Journey
.... Kev...
Old 09-18-2021, 11:32 PM
abc1mce2's Avatar
I can assume you use a plugin controller for your M7's (M7 link or M7 Control) for recall purposes?
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Carbon pre-purchase questions Bennett Paster Pro Tools | Carbon 8 08-13-2021 10:54 AM
Questions on Carbon Armando Pro Tools | Carbon 13 07-16-2021 11:40 AM
Basic questions about 11R rublalup Eleven Rack 3 01-27-2014 07:41 PM
Newbie questions on laptop PC selection - basic questions - thanks... half drag Windows 0 01-04-2011 01:12 PM
...some basic questions needing basic answers aponceenrile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2010 10:48 AM
