Pro Tools not receiving MIDI from USB
I took an Android phone and plugged it into a USB port and set the phone connection type to MIDI. If I open up a program like Pocket MIDI, then I see the new MIDI channel. Pocket MIDI sees note data coming into the channel when played on an Android keyboard. However, after rebooting Pro Tools, even though it finds the new MIDI channel, when I record enable it and select an output, the MIDI data fader does not light up when I play the virtual keyboard. Is there something special I need to do to get this to work? It seems like it should right out the box if PT recognizes the MIDI channel and data is passing through. |
Re: Pro Tools not receiving MIDI from USB
Are you trying to trigger an instrument in ProTools? If so, then create a new instrument track and load a VI into one of the inserts. It sounds like PT sees the connected phone as a MIDI device, so once you record enable the track you should be able to 'play' the instrument. Make sure your track output is set to the main output of your audio interface and you should be able to hear the output of the instrument.
Pro Tools suddenly stops receiving MIDI signal | Robusto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-17-2016 09:44 AM |
Pro Tools 11 not receiving MIDI signals | Lokooo | Pro Tools 11 | 7 | 02-20-2016 10:00 AM |
Vienna Ensemble Pro 5 not receiving MIDI from Pro Tools 11.2 | tokyo_teacher | Pro Tools 11 | 12 | 08-07-2014 10:10 PM |
Project Mix not receiving Midi | mistermyte | Pro Tools M-Powered (Mac) | 1 | 03-02-2007 02:39 PM |
Midi not receiving data | raj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-12-2001 06:03 AM |
