Old 05-15-2021, 05:10 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Unable to change buffer size
RME has, arguably, the best Windows drivers of any manufacturer, and they support their legacy products for years. I too can use my UFX for Windows sounds/audio, because the drivers are multi-client, but choose to take the conservative route and usually make my onboard soundcard the default for that.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Can't change buffer size, It is stuck in 512 and 1024. How can I do to change it? Ariel Chimba Pro Tools 12 9 12-23-2017 11:17 AM
So, When change H/W Buffer Size...... gonsdeejay Pro Tools 11 0 07-29-2013 09:12 AM
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Unable to change sample rate or buffer size with 11R MattBaron Eleven Rack 5 03-05-2012 03:39 PM
PT9 / Buffer size won't change narapo Windows 3 08-15-2011 02:59 PM
