Old 01-03-2011, 05:28 AM
[email protected] mjr@du.se is offline
Default Control of DigiDesign PRE
I have a Pro Tools 9 HD system using two DigiDesign 192 I/O and three DigiDesign PRE. I control Pro Tools using two MC Mix and one MC Control.
The PRE's har controlled through Pro Tools.
Is it possible to use my Euphonix surfaces to control the parameters of each channel on the PRE's?
Kind regards,
Mikael
Old 01-03-2011, 07:11 AM
mix109 mix109 is offline
Default Re: Control of DigiDesign PRE
Hi Mikael,
Once you have the Pre's connected via a Midi i/f ,and since PT9 adds Direct Eucon operability,i believe that the levels and functions of the Pre's should be controlled as they should-probably you have to select them via Insert Mode?
Old 01-04-2011, 01:15 AM
The PRE's don't show up as inserts in Pro Tools but as a seperate "Window View" above the inserts in the Mix window.
I can't find them in the MC Mix by selecting Inserts and entering assign mode. Maybe I'm looking in the wrong place?
Mikael
Old 01-04-2011, 09:25 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
It's not supported yet.
Avid Digidesign Control|24 and Sterling Modular Desk Console for Control 24-Separate relaxo Buy & Sell 3 09-05-2013 07:05 AM
WTB: Digidesign Control 24 andreconde Buy & Sell 0 06-05-2012 08:42 AM
STOLEN: Digidesign Pro Control Sir Charles the Audible ProControl, Control|24, Command|8 0 06-05-2006 09:30 AM
Digidesign pro control brad 3 Tips & Tricks 10 10-31-2003 07:19 AM
Digidesign Control Panel...N/W on G3 LesPaul666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-05-2001 07:44 AM
