Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 03-02-2023, 03:17 PM
pweinrobe pweinrobe is offline
Default Carbon via Core Audio only Showing 28 Outputs - Help!
Hi Everyone
I have a carbon hooked up in my studio where I use both Pro Tools and Ableton. My carbon has 16 channels of ADAT hooked up, and everything works perfect in Pro Tools.
The issue is: In ableton i can't access the last 10 output channels of the ADAT unit because Pro Tools is only reporting 28 core audio streams and it seams pro tools is using core audio streams 11-18 for the carbon headphone outputs, leaving only 10 left for the ADAT outputs.
(the adat inputs are functioning perfectly via core audio, fwiw)
anyone else using the Carbon like this as a CoreAudio device and finding that the last 10 channels of ADAT outputs don't seem to be accessible?
Avid Support? Any help?
Thank you!
Philip
Old 03-02-2023, 04:39 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Carbon via Core Audio only Showing 28 Outputs - Help!
Would it work using a third party routing app like www.gingeraudio.com?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-03-2023, 12:51 PM
dominicperry dominicperry is online now
You need to change the AVB configuration. If you're using Carbon Central, it's in there. If you aren't using Carbon Central, it's in Audio Midi Setup.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 03-09-2023, 04:26 PM
i tried changing all the AVB configs but none of them changed the amount of core audio outputs from 28 to 34 (what it should have theoretically).
at a serious loss as to how i am supposed to access these outputs via core audio
Old 03-10-2023, 04:47 AM
I just tried this using both AVB Setup and Carbon Central and you are correct - not possible to get more than 28 Core Audio outputs at any sample rate using any AVB configuration. I tested using Reaper but it's pretty clear that this is a Core Audio restriction, and isn't the case inside Pro Tools.
It makes no sense, I can't understand why this restriction should exist.
I can only suggest you log a case with Avid support - they don't turn up round here anymore with rare exceptions (and when they do, they only answer the "positive" questions - it gets more like Universal Audio every day).
Dominic
Old 11-20-2023, 02:10 PM
jlthermi jlthermi is offline
Hi
Did you have an answer from avid to your problem core audio problem?
thank you
Old 11-21-2023, 09:42 AM
I have the same kind of problem with the Carbon and the Dolby Atmos routing.
I have the first 10 analog outputs, 1 to 10 in the routing of the Dolby Atmos.
Then there’s a hole between 11 and 18 in the Dolby routing.
Then everything is ok with the first 8 outputs of the first Adat port (outputs 19 to 26 in the Dolby routing).
Then I have the 2 outputs of the second Adat port (27 to 28 in the Dolby renderer).
So there’s 6 Adat outputs missing because of this hole from 11 to 18 in the Dolby Atmos routing.
Everything is working fine in Protools.
Any idea why these outputs are missing?
Thank you
Carbon - can the “Main Monitor” outputs be configured as just “outputs”? massivekerry Pro Tools | Carbon 3 10-26-2022 02:12 PM
Setting outputs for Core Audio drivers?? BasketCase Pro Tools TDM Systems (Mac) 1 02-19-2013 09:47 AM
M-audio firewire 410 not showing outputs in MP9 Reggie TAE Pro Tools M-Powered (Mac) 2 04-23-2012 06:44 PM
Core Audio not showing up marlond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-02-2005 09:31 AM
Core Audio/192 Interface only 8 outputs?? mike16877 Pro Tools TDM Systems (Mac) 1 01-02-2004 05:13 PM
