Old 01-10-2023, 04:00 AM
stefanboman stefanboman is offline
Default S6 showing fader value 0.0 falsely
Why has my S6 starting sometimes show fader value 0.0 even thou the fader can be at -10.
As soon as I move it a tiny bit it then starts showing me the correct value.
It has been doing so for quite a while off and on.
Very annoying. How do I fix this?
Stefan Boman
Atlantis Studios-Stockholm
www.parkstudios.se
stefan[at]atlantisstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 01-10-2023, 04:39 AM
creativecontrol's Avatar
Default Re: S6 showing fader value 0.0 falsely
Greetings,
I would try a fader calibration. Go to Settings > Surface > then touch the Fader Module in question. Move all of the faders to their furthest extents then set each to 0 dB.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-10-2023, 07:02 AM
I'm pretty sure that it's not a fader calibration thing as all my faders is at zero(physical)if I create 32 new tracks.
I did a calibration a while ago and only a few faders that needed very minor adjustments.
Also, it can at times show the zero value(until I move it slightly)when the fader is at -30 as well.
So this must be something else.
Any ideas what to try?
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 01-10-2023, 07:22 AM
I would be curious if it is always the same fader within the module which is not reporting correctly?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-10-2023, 07:36 AM
No this can happen to most faders. Not always thou.
Which makes it much harder to resolve I guess...
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 01-10-2023, 10:41 AM
EddieJones's Avatar
Could this be to do with VCA spill ? (after)
Old 01-11-2023, 08:43 AM
I sometimes also have a VCA master. Which most often is kept at zero.
Could my VCA master value be shown on the individual channel(until I move it)?
Not sure what you(Eddie) mean with after.
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 01-12-2023, 03:15 AM
Hi again,
I made a video of my strange issue.
There was no VCA masters in this session.
https://www.dropbox.com/s/a5ipqoya87..._2776.MOV?dl=0
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 01-16-2023, 01:32 PM
Jeff, Eddie, any clues on this behavior from the video?
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 01-26-2023, 12:10 AM
Bump,
Jeff Eddie, any ideas from seeing the video?
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Dock fader showing wrong channel until touched OAG Avid S1, S3, Dock and Control App 1 07-22-2021 09:24 AM
S1 and showing fader groups copesetic Avid S1, S3, Dock and Control App 4 12-09-2020 09:59 AM
System Usage showing <10%, Activity Monitor showing >110%. What is going on?? colliderman Pro Tools 2020 13 06-17-2020 01:49 PM
SC48 Channel Fader showing as "OFF" BD123123 VENUE Live Sound Systems 3 11-24-2013 02:35 PM
FADER MUD - IMPOSSIBLE TO MAKE FADER WRITES IN REAL TIME Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2007 10:34 AM
