Old 11-16-2022, 01:33 PM
gthm's Avatar
gthm gthm is offline
Default Why are MIDI notes 1-2 samples ahead? 2022.9/2022.10
Why are MIDI notes a couple of samples ahead when I have clearly placed them on the grid? It happens with the first MIDI notes at the beginning of each session.
I start a session with a chord let's say, (at 0:0:000 right?) then I go to edit another track (audio or whatever) and when I come back to the Instrument track with the MIDI chord, the chord is now not snapped to the grid but has moved forward 1 or 2 samples (never more than 2 samples).
I opened some old sessions out of curiosity and there they are, MIDI notes are not snapped to the grid.
I noticed this in 2022.9, still there in 2022.10.
Very weird and annoying.
I hope I explained this right
Please see pic.
Pro Tools 2023.3
macOS 13.2.1
iMac (24-inch, M1, 2021)
(16GB RAM, 1TB SSD internal)
Samsung T7 x a few
Samsung 980 Pro x 2 (in Acasis TB/USB 4 enclosures)
Apogee Ensemble Thunderbolt
Old 11-18-2022, 07:46 AM
daeron80 daeron80 is offline
Default Re: Why are MIDI notes 1-2 samples ahead? 2022.9/2022.10
The MIDI spec was developed in 1983 as a way to connect synthesizers to each other, and wasn't designed for sample accuracy. Its resolution is measured in ticks per beat, and is therefore tempo-dependent. I think the MIDI resolution in PT is officially 960 ppq. It wouldn't surprise me greatly if it were possible these days to place notes more precisely than the official spec designates. But it's not capable of being arbitrarily sample accurate since it's dividing beats rather than seconds.
David J. Finnamore
PT 2022.9 Ultimate | Clarett+ 8Pre | macOS 13.1 on a MacBook Pro M1 Max
PT 2022.5 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 11-18-2022, 09:19 PM
nednednerb's Avatar
nednednerb nednednerb is offline
That is a very specific and succinct and to me very reasonable answer.
If the MIDI note is moved in musical time, it's "exact" as "the tempo" (deviation from error or "randomness"), while on sample time, it's 48,000 kHz or 44,100, etc, meaning the deviation from "musical time" (in ticks) is related to the BPM being overlaid on a sample rate. There is a mathematical association, but 1-2 samples is VERY close. Good on them, hah!
___
>> me: nednednerB //
||main gig: editing audio & testing software / 2nd gig: music software tutoring //
||software: Ventura 13.2.1 | PT Studio 2023.3 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB //
||devices: Focusrite Clarett 2Pre | some AT condenser mics | SM58 | Ableton Push 2 | 32" 4k LG secondary display //
||automation: SoundFlow | Keyboard Maestro | SteerMouse //
Old 11-19-2022, 05:35 AM
dcoffset dcoffset is offline
MIDI is old but it also seems there are strange things going on inside some DAW's if you're after very precise timing.
Below is a post with some tests that demonstrates the issues in different DAW: https://www.admiralbumblebee.com/mus...-7-Mixbus.html
By the looks of it MIDI timing in Pro Tools can deviate according to the buffer size. I have also found this when doing drum replacement - on converting the virtual instrument track to audio, you notice that timing may drift (which is not ideal :/)
It's also important to differentiate between virtual instruments timing and MIDI hardware. The latter might have other issues that impact on timing that are not related to the DAW.
Studio: Mac Pro | OSX Catalina | PT 2021.6 HDX | DAD AX32
Remote: Macbook Pro | OSX Catalina | PT 2021.6 Ultimate | UAD X8
Old 11-19-2022, 07:25 AM
climber climber is online now
BITD Dr.T's KCS on the Atari ST had incredibly accurate MIDI timing...
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
OS X Big Sur, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio , PT2022.12, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Melodyne doesn't render properly after TCE Tool 2022.10 and 2022.9 Dizzi45Z Pro Tools 4 01-04-2023 02:31 PM
Instrument Tracks Not Playing MIDI Notes - 2022.10 NateAlexander Pro Tools 1 11-05-2022 04:41 PM
2022.9 Can't grab MIDI notes borwick.alex Pro Tools 23 10-31-2022 12:21 AM
Can't select MIDI Notes after Quantizing them in 2022.6 [PT-289219] Dizzi45Z Pro Tools 93 10-18-2022 08:17 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
