Old 07-16-2013, 12:17 PM
JR13 JR13 is offline
Default Sound cutting in and out
Hi all,
Im having some issues with my Elevenracks sound cutting in and out while using ProTools and not. Within ProTools, the sound if my guitar cuts out periodically for 1-2 seconds and then comes back. When not using ProTools, the sound coming from my computer and going out through the headphones on my elevenrack cuts out periodically for 1-2 seconds but the guitar signal is unaffected.
Thanks
JR
Old 07-16-2013, 12:23 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Sound cutting in and out
Have you tried different cables?
Does this happen on all Sample Rates?
Doe this happen on all patches?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 07-16-2013, 03:05 PM
I've tried different cables and patches and them problem persists, how do I change the sample rate? I tried selecting a different clock source and I receive error messages whenever any option besides internal is selected. It seems like its locked at 48kHz
Old 07-17-2013, 02:00 PM
Benoni's Avatar
Did you try unplugging the 11R from the computer first? Did you try re-booting the 11R then change sample rates?
What kind of drivers are you using? Do you have some third party drivers installed like ASIO4All?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 08-04-2013, 11:27 AM
hi,
I changed the sample rates via the elevenrack and it seems to have solved the problem within protools. however when playing audio from my computer (ex a youtube video) the audio still freeze (for example, a youtube video will go silent for 1-2 seconds, then the video will freeze and the audio will play until it catches up to the video and both will play again in sync until the next loss of audio)
No third party drivers installed and I've installed the elevenrack drivers.
Old 08-04-2013, 03:35 PM
Benoni's Avatar
Sounds more like a problem with your PC.
What about changing the internal audio to be handled by the the PC and let the Eleven Rack just handle the Pro Tools audio.
Does that make a difference?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Sound cutting out solved... (Mbox pro 3) PC only risey Pro Tools 11 0 03-17-2014 03:41 PM
Sound cutting out mid session mwarn728 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2010 02:17 PM
Sound Cutting Out steverido 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 12-10-2009 12:11 PM
mbox micro sound cutting in and out... indoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-07-2009 08:51 AM
M-Audio Firewire 1814 Sound cutting out jasonguitar Pro Tools M-Powered (Win) 0 03-24-2007 08:16 AM
