Sound Cutting Out
Can anyone advise please? I have just setup my Pro tools LE 8 and when I am creating a track with instrument and play it back the sound is cutting in and out. I have increased memory usage but it is still doing it and with whichever VST I use. My computer is vey powerful so I don't understand why it is doing it. Thanks for any help. Steve |
Re: Sound Cutting Out
try a Sandra report and post it here.. So we have more info to work with.. :)
What buffer settings are you on? And what do you exactly mean with 'increased memory usage'?
Yours truly, Gerard [Keybeeetsss] Every time I see ur name "Gvees", I don't know why but I always start singin, "I-I-I-I-Stayin Alive, Stayin Alive: I-I-I-I-Stayin Aliiiiiveeeeee-Iiiiveeee-Iiiivvveeee-Iiivveeeee" |
Hi Gerard,
Thanks for the quick response. I have had to dual boot as my normal OS is Windows 7 x64. I am using Vista x86 to run Pro Tools and have adjusted memory to use 3 GB. I normally run on 4GB. I can't attach any Sandra reports yet as I have only just joined the site. My computer specs are Intel Dual Core 2 Duo E6850 @ 3Gig 4 GB of OCZ memory Creative Soundblaster X-treme music soundcard 2, EvGA 9800 GTX super super clocked graphics 1 KW PC Power & Cooling PSU 4, 300 GB Seagate Barracuda hard drives. 1, 750 GB Seagate Barracuda Hard Drive. I increased the buffer size to 2048 samples. RTAS 2 processors CPU limit 85% Disk buffer is level 2 cache - large I hope that this helps. |
Are you really using VST instruments?
I am using the the synths that came with Pro Tools for now. If I load Boom and playback the sound is jerky.
I have changed the buffer to 2048 samples, reduced processor to 1. Moved my page filing system and the playback and record to another hard drive and still it is jerky. I am wondering whether I need to uninstall and reinstall the program. Any advise out there please? |
To enable other users to help you, please include all of your system details when posting an issue to the DUC; Pro Tools hardware, Pro Tools software version, CPU, OS version, Motherboard make/model, chipset, amount of RAM, type of hard drives used, etc. - Please - Use SiSoftware's Sandra Lite application to generate a full system profile: Sandra Report Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I am using Pro tools LE 8. M-box mini, Oxygen 49 keyboard, Vista x86 SP2.
I have changed the processor to 1. As I have said before I can't attach any files. I am assuming because I have recently registered. If you look at my earlier posts I have changed a lot of my system configuration as shown in another thread about setup and configuration. |
A Sandra Report is cpoy/paste, no attaching. That's why we use it.. :)
Try getting rid of the other soundcard you have in there. That might help...
SiSoftware Sandra
System Host Name : SteveMorris-PC User : Steve Morris Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 Duo CPU E6850 @ 3.00GHz Speed : 3GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing System System : EVGA 122-CK-NF68 Mainboard : EVGA 122-CK-NF68 Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes BIOS : Phoenix Technologies, LTD 6.00 PG Total Memory : 2.25GB Chipset Model : nVidia C55 Host Bridge Front Side Bus Speed : 4x 333MHz (1.33GHz) Video System Adapter : 2x NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.7GHz, 512MB DDR3 2x1.12GHz, PCIe 1.00 x16) Adapter : 2x NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.7GHz, 512MB DDR3 2x1.12GHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 9800 GTX+ (128SP 1.84GHz, 512MB 2x1.12GHz) Adapter : GeForce 9800 GTX/9800 GTX+ (128SP 2GHz, 512MB) Storage Devices ST3320620AS (320GB, RAID, 3.5", NCQ) : 298GB (G:) ST3320620AS (320GB, RAID, 3.5", NCQ) : 298GB (E:) ST3320620AS (320GB, RAID, 3.5", NCQ) : 298GB (F:) ST3750640AS (750.2GB, RAID, 3.5", NCQ) : 699GB (D:) ST3320620AS (320GB, RAID, 3.5", NCQ) : 298GB (C:) PHILIPS DVDR1640P (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (H:) PEHEXQJ TQBKLYR (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (I:) PEHEXQJ TQBKLYR (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (J:) Logical Storage Devices Hard Disk (G:) : 298GB (NTFS) @ ST3320620AS (320GB, RAID, 3.5", NCQ) Hard Disk (E:) : 298GB (NTFS) @ ST3320620AS (320GB, RAID, 3.5", NCQ) New Volume (F:) : 298GB (NTFS) @ ST3320620AS (320GB, RAID, 3.5", NCQ) Hard Disk (D:) : 699GB (NTFS) @ ST3750640AS (750.2GB, RAID, 3.5", NCQ) New Volume (C:) : 298GB (NTFS) @ ST3320620AS (320GB, RAID, 3.5", NCQ) Optical Drive (H:) : N/A @ PHILIPS DVDR1640P (ATA33, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (I:) : N/A @ PEHEXQJ TQBKLYR (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Optical Drive (J:) : N/A @ PEHEXQJ TQBKLYR (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Peripherals LPC Hub Controller 1 : nVidia MCP55 LPC Bridge Audio Device : Creative Labs Sound Blaster X-Fi XtremeMusic Serial Port(s) : 1 Disk Controller : nVidia MCP55 IDE Disk Controller : nVidia MCP55 SATA Controller Disk Controller : nVidia MCP55 SATA Controller Disk Controller : nVidia MCP55 SATA Controller USB Controller 1 : nVidia MCP55 USB Controller USB Controller 2 : nVidia MCP55 USB Controller FireWire/1394 Controller 1 : nVidia TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : NVIDIA nForce Networking Controller (Ethernet, 100Mbps) Network Adapter : NVIDIA nForce Networking Controller #2 Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Ultimate 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 1.0 SiSoftware Sandra General Information Manufacturer : (Standard USB Host Controller) Device Name : Standard OpenHCD USB Host Controller Type : USB Hardware ID : PCI\VEN_10DE&DEV_036C&SUBSYS_C55E10DE&REV_A1 Location : PCI bus 0, device 11, function 0 ID : \Device\NTPNP_PCI0022 Device Enumerator : PCI Hardware Resources Memory Range : CFFFF000 - CFFFFFFF Irq. No. : 20 Service ID : usbohci File Information File Types : Library Operating System : Windows NT File Description : OHCI USB Miniport Driver File Version : 6.00.6002.18005 Product Description : Microsoft® Windows® Operating System Product Version : 6.00.6002.18005 Manufacturer : Microsoft Corporation Copyright : © Microsoft Corporation. All rights reserved. File Size : 19kB File Date : 26 November 2009 Digital Signature Information Name : Microsoft Windows Information URL : http://www.microsoft.com Timestamp : 11 April 2009 @ 10:50:43 Signer Information Version : V3 Name : Microsoft Windows RDN - Relative Distinguished Name : US, Washington, Redmond, Microsoft Corporation, AOC, Microsoft Windows Serial Number : 61 01 e1 a1 00 00 00 00 00 08 Valid : Yes Valid From Date : 12 December 2008 @ 22:12:30 Valid Until Date : 12 March 2010 @ 22:22:30 Issuer Information Version : V3 Name : Microsoft Windows Verification PCA RDN - Relative Distinguished Name : US, Washington, Redmond, Microsoft Corporation, Microsoft Windows Verification PCA Serial Number : 61 01 e1 a1 00 00 00 00 00 08 Valid : Yes Valid From Date : 12 December 2008 @ 22:12:30 Valid Until Date : 12 March 2010 @ 22:22:30 Timestamper Information Version : V3 Name : Microsoft Time-Stamp PCA RDN - Relative Distinguished Name : US, Washington, Redmond, Microsoft Corporation, Microsoft Time-Stamp PCA Serial Number : 61 04 ca 69 00 00 00 00 00 08 Valid : Yes Valid From Date : 05 June 2007 @ 22:03:21 Valid Until Date : 05 June 2012 @ 22:13:21 |
Tried it without the Creative soundcard and it is the same.
If I start pro tools and create a new track and add a click then add Boom and play back a pre-loaded beat sample it cuts in and out. I have now run out of ideas aprt from reinstalling windows clean and pro tools. |
Sound cutting out solved... (Mbox pro 3) PC only | risey | Pro Tools 11 | 0 | 03-17-2014 03:41 PM |
Sound cutting in and out | JR13 | Eleven Rack | 5 | 08-04-2013 03:35 PM |
Sound cutting out mid session | mwarn728 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-16-2010 02:17 PM |
mbox micro sound cutting in and out... | indoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-07-2009 08:51 AM |
M-Audio Firewire 1814 Sound cutting out | jasonguitar | Pro Tools M-Powered (Win) | 0 | 03-24-2007 08:16 AM |
