Pro tools keeps using Eleven rack instead of digi002.. among other weird probs..
Hi.. absolutely at random, when I boot up my system...and load pro tools.. it ignores my digi002 and uses the eleven as the control..
I then have to reboot a series of random times in order for it to pick the digi002.. I have to have the Eleven on during pro tools bootup in order for it to load the eleven RACK in pro tools... so waiting till after PT loads to turn eleven on doesn't seem to be an option. Lastly .. on the Eleven rack...in order for it to embed rig settings, I have to go into User Options every single session and tell it to get rig settings from the inputs.. is there not a way to just make this setting stick so I don't have to do this every session every song every time? Thanks!! S |
And holding down the N key during PT startup does not let you pick the interface?
Darryl |
Re: Pro tools keeps using Eleven rack instead of digi002.. among other weird probs..
nice tip..thank you.. just tried it and that seems to work.. strange because it just always defaulted to the 002 until today..
any clue about the user options> rig settings ? Is there a way to do that so it saves the setting ....right now I'm having to set that every single session..and it seems it should just be able to do it automatically. |
I do not know for sure where this is saved, I assume in the Pro Tools prefs. Its obviously not a real Eleven Rack option setting (e.g. not stored in the Eleven Rack) and its not specific to the rig or a Pro Tools session. I've never had a problem saving this so not ever had to try to debug what is going on. You might want to try trashing prefs and seeing if the behavior changes (if you dont' know how to trash/delete prefs see http://duc.avid.com/showthread.php?t=54888). Some other guesses... If you don't switch/are forced to switch interfaces does this happen to you? Do you have "session overwrites current I/O" set in the IO dialog (just a complete guess but try turning that off). Darryl |
Eleven Rack Digi002 Rack Set Up | RichardWard | Eleven Rack | 28 | 08-05-2013 09:44 PM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
weird midi probs ptle7 | sammyfarr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-13-2006 11:53 AM |
Pro Tools & Digi002/Digi002 Rack/M-Box | Kavie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-09-2005 02:33 PM |
