Old 06-23-2009, 09:00 PM
djkaz djkaz is offline
Default how to install 2 different versions of protools on one computer?
hi all! i've got 2 protools setups: 1 protools hd setup i use in my studio, and 1 m-audio setup for my laptop. unfortunately, my 192 i/o is doing that thing where you get static in one channel, except it's in EVERY CHANNEL. so, till i can come up with both $300+ bucks to repair it, plus ~$400 for 2 round trip tickets to jakarta (and the nearest licensed digi technician) i'm gonna have to use my m-audio setup for recording, and my hd system for mixing.
however, while i have a license for both protools hd 8.0 AND protools m-powered 8.0, i cant seem to install both on my system. the install setup routine wont let me choose the install path during installation, so the two versions just continue to write over each other. is there some trick i'm missing here to do this?
Old 06-24-2009, 12:30 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: how to install 2 different versions of protools on one computer?
You'll need to clone your system drive on to another hard drive partition (carbon copy cloner) and install MP on the clone. first remove HD from the clone partition and trash all prefs using this app...
http://duc.digidesign.com/showthread.php?t=190122
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-24-2009, 05:21 AM
Oddbod Oddbod is offline
Thanks Chris,
I joined this community to ask the same question!
Useful link.
O-B
Old 06-24-2009, 09:30 AM
Scott Goldberg Scott Goldberg is offline
however, while i have a license for both protools hd 8.0 AND protools m-powered 8.0, i cant seem to install both on my system. the install setup routine wont let me choose the install path during installation, so the two versions just continue to write over each other. is there some trick i'm missing here to do this?[/QUOTE]
Chris is correct. We both have cloned drives and I have a version of 7.4 on one of my drives which keeps me safe and happy if something goes terribly wrong. Get Super Duper and use is as a cloning device. It's cheap, I think $30, and it works greet.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 06-24-2009, 11:35 AM
Ozzie Ozzie is offline
Have you tried opening the 192 and reseating the edge connectors?
This has worked for me in the past, heat can cause movement and the contact can be lost between card and connector.
Worth a try.
Regards
Old 06-24-2009, 11:43 AM
Sean Russell Sean Russell is offline
You need to install on a separate hard drive. Clone to new drive, remove everything PT and install new PT. Name one drive LE and one HD if need to.
... but does it help the chorus?
Old 06-26-2009, 11:13 PM
well, that kinda sucks - i've already got my system drive superduping once a week to a second backup hard drive, adding 2 more drives just to run another version of protools seems like expensive overkill, but i absolutely dont want to stop backing up my system drive. surely there's another way?!?!?
Worth a try.
any instructions online on how to do this? the warrantee is long expired anyway, and i'm used to the insides of computers already so maybe this is something i could do myself... if only i knew what an edge connector was!
Old 06-27-2009, 01:36 AM
crizdee's Avatar
It doesn't have to be a new hard drive! just a clean partition big enough to clone your system drive to. i have 3 different boot systems on partitions.
Chris
Producer, Engineer,
www.ukmastering.com
how to install 2 different versions of protools on one computer? djkaz Pro Tools M-Powered (Mac) 5 06-26-2009 11:14 PM
Can I install 2 different versions on the same computer? bigpip General Discussion 2 10-06-2007 11:01 AM
multiple versions of ProTools on one computer? KingTor Pro Tools TDM Systems (Mac) 4 09-15-2006 12:01 PM
install ALL Updated Versions of ProTools? MrJakie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-09-2006 09:50 AM
2 ProTools versions on same computer? didger Pro Tools TDM Systems (Mac) 2 07-04-2003 09:07 AM
