Old 06-21-2004, 08:41 AM
Bassman3141 Bassman3141 is offline
Default Intermittent XP system sounds with Mbox
I can't get system sounds to reliably play thru my Mbox. 3rd party apps (WMP, Winamp) play audio CDs, but with frequent dropouts.
I installed the WaveDriver (6.1.1). I selected the Mbox as my default playback device in Ctrl Panel. I also used the DigiMME Helper to assign the WaveDriver to certain apps. No change.
Do I need to remove/disable my other sound card? Any other ideas?
Old 06-21-2004, 11:11 AM
underbiteman underbiteman is offline
Default Re: Intermittent XP system sounds with Mbox
see these posts
does mbox wavedriver suck for you too?
Winamp ASIO Driver for media playback with digi HW
Old 06-22-2004, 08:47 AM
Works like a charm. Thanks a bunch!
Old 06-22-2004, 10:25 AM
I spoke too soon. I still have skips in audio - both MP3s and system audio.
I followed your post and did the following:
1) installed Winamp5
2) downloaded the ASIO DLL and copied it to Winamp5 plugin directory
3) removed and reinstalled Wavedriver (including vestigial DALWDM.SYS files)
The Mbox now appears as a sound card in Ctrl Panel and 3rd party apps. I successfully routed the above audio sources thru my Mbox. But they still dropout intermittently. When played thru my PCs sound card, there are no dropouts.
Questions:
1) The Wavedriver allows me to redirect audio bound for my sound card to the Mbox. I dunno what the ASIO driver does. Do I need BOTH of them?
2) One post said "obviously you need to be running PT6.1 + asio for it to work." I assume this is not literally. I mean, PT doesn't need to be running just to get a system sound, right. Sounds lame, but I'm at my wit's end.
Any other ideas?
Old 06-22-2004, 11:30 AM
Did you go to preferences on winamp and set the output as asio driver or wave out driver?
Old 06-22-2004, 01:03 PM
If I direct Winamp5's output to the ASIO plugin, audio comes out of my soundcard.
If I set the output to the waveOut plugin, it works as long as I configure the plugin's output device to be the Mbox. However, the resultant audio has dropouts in it.
The more I think about it, it seems like the ASIO DLL (ver 0.45 SSE2) has no effect. And the ASIO readme file is unreadable.
Does that make any sense?
Old 06-22-2004, 07:48 PM
when you choose asio out, press configure and pick digidesign's asio. That worked for me.
Old 06-29-2004, 03:49 PM
I got it to work. Due to another nightmare, I had to reinstall XP. Now, I follow this procedure and it works great.
It's more proof of my theory - when in doubt, reinstall Windows.
Mbox 3 - No Playback or System Sounds jackmanndxb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-06-2013 01:55 PM
Sending System Sounds through MBox using Wavedriver RJO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-10-2010 07:12 PM
can't play XP system sounds or iTunes thru Mbox Bassman3141 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2005 04:06 PM
System sounds & MBox robbins876 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-22-2003 12:00 AM
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds brownmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-30-2003 03:22 PM
