Old 03-25-2021, 01:11 PM
koka koka is offline
Default HDX Firmware Upgrade
Hi any info about HDX firmware Upgrade with 2021.3 ?
Is it Safe?
Old 03-25-2021, 01:17 PM
Default Re: HDX Firmware Upgrade
I just did it for HD Native TB on Mojave and it was painless. Took 2-3 minutes and required a shutdown, 5 second wait, then a startup. Everything is working fine so far.
Scott Gatteño
Old 03-25-2021, 01:28 PM
BScout BScout is offline
Working fine here since it was released this morning. 2 cards were updated with no issue (on High Sierra -- so no longer officially supported but I'm guessing that's more a "wasn't tested" scenario as Avid usually discard an old macOS when they add a new one to keep the number of macOS versions needing to be tested manageable.)
Old 03-25-2021, 02:19 PM
glogulus2003 glogulus2003 is offline
I just updated both HDX cards in my system on Big Sur without issue. I'm hoping that interrupt change means no more dropouts with small buffer sizes.
Old 03-25-2021, 03:19 PM
off the wall's Avatar
Single HDX card, Mac Pro 5,1 MacOS Mojave. No issues with the firmware update. Took only a couple of minutes and a cold start.
offthewallproductions
Old 03-25-2021, 03:22 PM
RossH RossH is offline
Successful firmware update here. Single HDX card, Mac Pro 5,1 High Sierra.
Control Room: PT Ultimate HDX 2023.3.0 // Mac Pro 2012 // Mojave 10.14.6 // BlackMagic DeckLink Intensity Pro // Genelec 5 x 8250A + 7270A DSP Active Subwoofer // Yamaha NS-10's
Edit Suite: PT Ultimate 2023.12.1 // Mac Pro 2013 // Monterey 12.7.3 // Focusrite 18i20 // Genelec 5 x 6010A + 5040A Active Subwoofer
Video Suite: PT Ultimate 2023.12.1 // iMac Pro 2017 //Monterey 12.7.3 // Focusrite Scarlett Solo
Old 03-26-2021, 03:26 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Very glad to hear it works on High Sierra.
Is the firmware update mandatory in order to run Protools? I just need to check a bug, the fix list is a bit vague about it, and rather not update a working system...
Old 03-26-2021, 05:29 AM
nebosphere nebosphere is offline
Single HDX card here, updated fine. Anyone notice a change in behavior? Seems to be about the same at low buffer settings here.
Old 03-26-2021, 07:32 AM
Yes
Old 03-26-2021, 08:50 AM
TOM@METRO's Avatar
On Windows 20H2, the firmware update was fast and smooth..
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Did somebody upgrade MC Mix firmware? Durcu Artist Series 2 02-15-2011 12:17 PM
Firmware upgrade NathanLee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2007 11:35 AM
Mac G5 Firmware Upgrade MidiMe Pro Tools TDM Systems (Mac) 5 01-03-2005 05:12 AM
002 firmware upgrade Antihero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-26-2004 06:05 AM
6.4 firmware upgrade? henke b 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-20-2004 12:27 PM
