Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 06-02-2021, 08:15 AM
22002fede 22002fede is offline
Default Sidechain delay compensation fixed for Carbon and Hybrid HDX
Hello everyone,
For who was wondering, Sidechain delay compensation will be available for hybrid HDX mixers from the next protools update. And it will work for both Native and DSP plugins. The nagging has been finally heard!!
Here I attach their answer:
Hi Federico,
Carbon and the Hybrid HDX Engine both use the same technology, so in fixing the sidechain ADC for Hybrid, it will also be fixed for Carbon.
Sidechain ADC will work for both Native & DSP plugins.
This will be available with the next release of Pro Tools before the end of June.
Do you have any further questions?
Best Regards,
Maciej
Avid Global Customer Support
Old 06-02-2021, 09:08 AM
XJENSEN XJENSEN is offline
Default Re: Sidechain delay compensation fixed for Carbon and Hybrid HDX
Great that they finally got to fixing all the ADC issues because of their new Carbon product. Should have happened long ago.
And as expected, the side chain compensation will remain an HDX-only feature.
Old 06-02-2021, 04:38 PM
Sardi Sardi is offline
If it’s going to work with native plugins, then how is it only tied to HDX?
The way I read the statement, it appears it will work with all versions of Pro Tools and any type of plugin format.
Old 06-03-2021, 01:34 AM
From the statement, it seems it will only be available for the (hybrid) HDX mixing engine that's used when you have either Carbon or an HDX system. You will of course be able to run Native plugins on an HDX system as well, but this doesn't mean this feature will be coming to the Native mixing engine.
Old 06-03-2021, 02:34 AM
Hmmm... I guess we’ll have to wait and see.
Old 06-05-2021, 08:07 AM
@tention @tention is offline
Fingers crossed. I hope they finally managed to get this done properly with native systems.
SOUND!
Old 06-07-2021, 09:25 AM
digiot digiot is offline
The Hybrid engine uses the native mixing engine! It takes all mixing tasks away from the DSP and only utilizes the DSP for DSP-enabled tracks and associated paths. The downside to the Hybrid engine is that you can no longer mix DSP and Native plugins on the same track. You can mix Native and DSP within the session but as soon as you enable DSP on a track it disables the Native plug-ins on that track.
Old 08-02-2021, 11:51 PM
LoZion's Avatar
LoZion LoZion is offline
How are hardware inserts affected by the new hybrid engine?
"The secret in life is to have no fear"
Fela Anikulapo Kuti
Avid Carbon sidechain delay compensation 22002fede Pro Tools HDX & HD Native Systems (Mac) 1 04-23-2021 05:15 PM
HDX Sidechain Delay Compensation Broken? Drywsef Pro Tools 2020 6 03-18-2021 07:10 AM
Commit and Sidechain Delay Compensation Glo123 Pro Tools 2020 0 01-09-2021 11:25 PM
Sidechain Delay Compensation JingleDjango Pro Tools 2020 6 06-17-2020 06:02 PM
Workaround for sidechain delay compensation? DJ Hellfire Pro Tools 12 8 07-15-2017 09:37 PM
