Axiom Pro25 pads interrupt keys
Hi!
Another problem: in PT9 when i use the pads, the backlight of all buttons (except the function switch key) goes off and after one second on again. Inbetween this time the keys can't do nothing... Pleasepleaseplease FIX ALL THE BUGS in hypercontrol, thank you...
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: Axiom Pro25 pads interrupt keys
That Axiom Pro behaviour dates back to Pro Tools 8.x.
Aaron Mulqueen - 001 HD Native |
Yes, true but seriously, a protocol like hypercontrol shouldn' t be "outdated" after such a short period...
Who said HyperControl is 'outdated'?
i thought you meant that with your statement.
When does a bug constitute HyperControl being outdated?
it seems that the developement of HyperControl can´t catch up to the developement of the latest PT versions. And this is not the only bug right now, isn´t it?
What are they saying over at M-Audio forums?
It's quiet in that forum. But now read this:
For an unknown reason my Axiom Pro 25 suddenly worked with ProTools9! Mute button did mute and not solo, F2/3 buttons did select tracks. Eveything was fine - for 5 minutes... After reopening the same session, it had its common wrong behaviours again. I changed nothing, my setup is like it was before.
That happens if you trash your preferences and create a new session. Or creating a new session for the first time as a new user.
Assigning Axiom Drum Pads to Redrum...! | KingAce | MIDI | 6 | 11-29-2012 02:33 PM |
Assign Drum Pads Axiom 25 Battery 3 | Space Firebird | MIDI | 4 | 02-02-2012 12:11 PM |
Axiom 25 Keys with Essentials | Goo-D-Man | MIDI | 0 | 09-17-2010 07:27 PM |
Transfuser pads mapped to axiom pro pads | th3actor | Virtual Instruments | 0 | 09-02-2010 04:22 PM |
axiom 49 drum pads will not trigger strike | jackp | Virtual Instruments | 4 | 03-14-2008 02:36 PM |
