Re: I need a new video capture card!
I've got a canoupus advc100. mmmmmhhh [img]images/icons/frown.gif[/img]
It's the only one certified! It's not a great piece of gear since firewire video has a dalay (that should be fix by protools-movie-set movic sync offset). But you'll find two problems: 1) when you are in pause or you place the cursor in the edit window, moving in your session, canopus will display a a "flashing frame". 2) When you scrub a track, or you play slower or faster then normal speed, canopus will loos sync! Digidesign know this problem. But seems to be the only solution, if you don't want to buy an avoption ( i don't think works on protoools le). ...... Last but not the least!! If you take a look at prootols video\ sync compatiblity you will discover digidesign has recently certified Ati Radeon 8500. I dont' kwon this card, and if it works right but i can tell you that it has at least a vga output and a svideo output. So you can display protools winows on a mac display and video on a tv. I acutally use a similar configuration with a dual head videocard. Since i dispaly video inside computer ( like miro dc 30) i have no delay. I think you can do the same with ati radeon 8500. Hope this helps [img]images/icons/smile.gif[/img] |
I don't do a lot in video, but this note was sent out a few days ago...
Aurora Video Systems Announces IgniterX Lite Certification for Pro Tools 6.0.1 TDM Systems on Mac OS X Aurora Video Systems announced that its IgniterX Lite video capture card has been qualified with Pro Tools 6.0.1 TDM systems on Mac OS X, bringing digital audio workstation (DAW) users an affordable, high-performance capture solution for the Mac.**The IgniterX Lite offers**leading data rates and a high offline compression ratio, saving drive space while providing editors with a flexible platform on which to create and synchronize audio to video. |
Hi there
Since the Aurora Fuse does not support OSX, I need a new card. I have been looking at the Canopus advc100 capture unit. Does anyone have any user info on this box? Is it any good? Thanks for your help Pindebraende |
you can also try old DC30+. Someone did free OSX drivers. (do a search)
Jack |
Thanks all
Pindebraende |
Don't do the DC30 (they really suck and there is NO support). Canopus is great for PCs but there Mac stuff is severely lacking. I upgraded my Fuse to an Igniter LT (details are on Aurora's website) for cheap. Since then I upped to an Igniter RT011 (now Igniter X). VERY happy with the card and it's support.
lucky,
you're right, ther's no DC30 support for years, but It simply works. I'll not spend a single penny on Aurora since they left my $500 Fuse card without support. $750 Ignitier LT upgrade is not cheap for me. Jack |
you're right, ther's no DC30 support for years, but It simply works. --------------------------------------------------------------- very true. i'm using the DC30 for about 5 years now. never had any problems with it. there are even osX drivers for the card. quiality is obviously lower than DV (like canopus etc...) - but it is allways in sync.
DesignInSound |
Which video capture card can send H.264 video out to a TV from PT11 | jgagne1 | Pro Tools 11 | 1 | 01-16-2014 12:59 PM |
Looking for Video Capture Card | georgia | Post - Surround - Video | 4 | 10-01-2003 04:00 PM |
Need Video Capture Card | mampam | Post - Surround - Video | 3 | 01-31-2003 11:47 AM |
re: VIDEO CAPTURE, Fuse card is approved but will Igniter card work as well? | ragbor | Pro Tools TDM Systems (Mac) | 0 | 12-08-2000 11:56 AM |
PT3 video capture card? | lpeacock | Pro Tools TDM Systems (Mac) | 1 | 01-24-2000 07:50 PM |
