Old 11-25-2022, 02:16 AM
chrisVVS chrisVVS is offline
Default Source Nexus noise bursts on closing session
Here's an unusual one someone might have experience of.
I use Source Connect to connect to other studios for voiceovers. I use Source Nexus to route Source Connect, Zoom, Teams, Cleanfeed etc into Pro Tools. When I close the session I get a huge blast of noise.
I spoke to the people at Source Elements, who told me that it was because the Nexus plug-in closes down before Pro Tools does, causing a feedback loop for an instant before the session closes. I can confirm this - if I open the session without the Source Nexus iLok (meaning it won't open when Pro Tools opens) then I get the same feedback.
Great. I understand why. But why is nobody else experiencing it apart from me? Any clues?
Old 11-25-2022, 10:49 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Source Nexus noise bursts on closing session
I can't answer your question directly, but maybe you could try the trial from www.gingeraudio.com and see if it does the same thing.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-25-2022, 11:11 AM
audiobob's Avatar
audiobob audiobob is offline
I've owned SN for over a year doing the same type of work and never had this issue. Are you on Mac or Widows. What interface are you using?
Old 11-25-2022, 04:52 PM
mattrixx mattrixx is offline
I'm using SN in the same way and have all of the SN tracks in a routing folder and mute that when it's not ins use.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 11-28-2022, 07:20 AM
Thanks all. I'm using a Rubix 44, but it happens wth all my otjer interfaces too. I've spoken to the people at SC and they've got my template, but I'm still trying to work this out.
I've attached a link to a short video of my entire template showing what heppens when I activate and deactivate the talkback track feeding the sends -
https://dropover.cloud/e46982
Old 11-28-2022, 07:30 AM
sw rec sw rec is online now
Mute the output before you close it?
Old 11-28-2022, 07:53 AM
its2loud its2loud is offline
You don’t need these extra Auxes. They’re redundant and not necessary.
Create your sends from the original input tracks as the arrows point back to in the photo.
File Type: jpg 3D90221C-AC10-45DE-A5C9-6D4E1E8C3A71.jpg (70.4 KB, 0 views)
Old 11-28-2022, 08:49 AM
You're suggesting that I put the sends on the SC I/O tracks instead?
Old 11-28-2022, 09:08 AM
Moving the sends to the IO tracks gives the same result as leaving them on the AUX tracks but it's more convenient to be able to change level from the track I'm listening on. Can anyone see an advantage to putting the sends on the IO tracks? Also, SC support have told me 'It makes sense that the feedback is caused by the talkback channel routing setup. so I'm hoping someone can help. Could anyone provide their template..?
Old 11-28-2022, 11:47 AM
Remove Muteomatic on your TB input and see what happens. Put a signal generator on your TB input and chase the routing of that talkback mic. Is it looping back around to your inputs? Are any of your Source Nexus plugins in "thru" mode? Can't tell from the video
It's too hard to determine where the issue is without digging into your session. If you want to share you session template that might help.
Source Nexus Alternative Ben Wood Pro Tools HDX & HD Native Systems (Mac) 17 08-04-2023 04:19 PM
Source-Nexus vs Source-Connect Standard ??? EGS Windows 20 06-10-2022 10:52 AM
Source Elements releases Windows version of Source-Nexus sourceelements Partner Announcements 0 01-31-2022 08:21 AM
Sale: Source Elements' Source Nexus Basic and Pro SoundByLaura Buy & Sell 1 01-01-2017 08:30 PM
Noise bursts and clicks when opening session janmuths 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-05-2008 09:13 PM
