Old 10-28-2022, 07:15 AM
Ru_C Ru_C is offline
Default Can't get Aux i/o to stream from Logic. Anyone else?
Just testing the latest Pro Tools with my M1 home setup (specs in signature) & trying out the great new aux i/o feature, testing out apps on my system
Safari - works as expected, & sample rate converts to 96k on the fly
Garageband - works as expected, & sample rate converts to 96k on the fly
Guitar pro 7 - works as expected, & sample rate converts to 96k on the fly
Reason 11.3.9 - Doesn't like 96k
Logic 10.7.4 - I can't get to use Aux i/o at all. I select it in Logic's usual audio prefs settings, & it merrily just plays though my interface in the background ignoring Pro Tools.
Anyone else having luck?
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 10-31-2022, 04:27 AM
Default Re: Can't get Aux i/o to stream from Logic. Anyone else?
<bump>
No one else try this yet? I'm trying to work out if it's a Logic problem, A Pro Tools Problem, or my setup.
Cheers
Old 10-31-2022, 06:11 AM
creativecontrol's Avatar
Make sure Logic and Pro Tools are set to the same Sample Rate. I have a very similar setup to your B rig and just validated all of this is working fine. Please see the following:
https://www.dropbox.com/scl/fo/829hd...cxppfafpgya0tv
Let us know.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-01-2022, 09:56 AM
Let us know.
best,
Jeff
Hi Jeff, thanks for replying. Right I've done more testing & just can't get it to work on my system.
Ive created two project, one at 44.1k & one at 48k..& have included a Logic file with each.
These are just single track project with a Logic 'Drummer' trying to stream into Pro Tools.
I've set it up identically to the way you have shown on dropbox.
On my setup, I can hear sound from Logic, but it goes straight to the speakers, rather than via PT's Aux as it should. As mentioned before. If I launch Garageband instead of logic, it behaves 100% as expected with Aux i/o
This is a link to the sessions here. Would be great if you can take a look & tell me if its pilot error, or something else.
https://www.dropbox.com/sh/ec1aaf1gt...1FmNsWyna?dl=0
Cheers
Old 11-01-2022, 10:31 AM
Cheers
Ok update, if I use inputs 3/4 rather than 1/2 of the bridge it now works (see screengrab)...when using bridge inout 1/2, the behaviour is as reported before..
Old 11-02-2022, 05:31 AM
I'll take a look - but this doesn't make much sense ->
On my setup, I can hear sound from Logic, but it goes straight to the speakers...
If the Audio output in Logic is assigned to a virtual destination like PTAB - how can it be hitting the speakers? Also please indicate your playback engine in Pro Tools. I presume it is a Focusriute 2i2. Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-02-2022, 06:22 PM
hurdy gurdy hurdy gurdy is offline
I can also stream fine from Logic (Logic audio out settings set to "PT audio audio bridge 2-B") into an armed Pro Tools audio track "Pro Tools audio bridge 2-B" (and of course PT output set to my monitors for hearing playback). Plays back/records fine unless I'm confused what you're doing versus what I'm doing. Mileage varies -I'm doing this on M1 mini/16 ram UA twin x but haven't tried on my Avid, Focusrite, interfaces, etc. Good luck though I can relate -frustrating when there's problems.
len b
Stream from one SSD or two? Natanel Arnson Windows 12 10-08-2014 03:23 PM
End Of Stream zoomex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-16-2011 07:19 AM
DV stream help---I need 23.976 stormmusic Post - Surround - Video 14 05-18-2007 06:27 PM
Digi Stream Manager & Logic 7.2 Fader Invader Pro Tools TDM Systems (Mac) 1 08-15-2006 02:04 AM
Mp3.com - Why cant I stream it? Ben Jenssen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-08-2002 01:50 PM
