Old 12-04-2022, 07:37 PM
danrhenry danrhenry is offline
Default i Cant use any channel past 16 on my Presonus 32.4.2
The specs say 32 ch I/O but i cant record or mix on any channel greater than 16 on my board. I don't want to get my monitor mix back on 1/2. Presonus uses 33/34 for return monitoring. I would settle for 31/32, but nothing over 16 works. So since I have to use 1/2 for monitoring I really have a simultaneous recording max of 14 tracks. Is that right? 17/34 appear in the I/O matrix. Just no audio. (ARTIST). It looks like they just cut my board in half.
Old 12-04-2022, 08:43 PM
Default Re: i Cant use any channel past 16 on my Presonus 32.4.2
What specs are you looking at?
Pro Tools Artist limits:
32 tracks
16 simultaneous inputs.
Spelt out very clearly: https://www.avid.com/pro-tools/comparison.
Tracks limits and I/O limits are frequently quite different.
Edit: had to think how Pro Tools normally does this. Assuming Artist behaves the same as Studio etc. then the way around this is to remap I/O in the interface/onboard mixer to be I/O ports physically below the limit, if the interface supports that. No idea if the Presonus can do that. Maybe you can physically connect the monitor mix back to some other inputs if there is no other way. Or upgrade to Pro Tools Studio (64 IO limit) or use a different DAW. Lots of great DAWs out there, Reaper would be top of my list on Windows. And there is Presonus' own Studio One (which I've never used).
Old 12-05-2022, 07:53 PM
Top Jimmy's Avatar
Use Presonus' Capture to grab all 32 tracks. Then you can move those into Pro Tools if it's your prefered editing/mixing environment.
James Cadwallader
no audio past channel 32 in a 64x64 Dante setup? naughty G Third Party Interfaces 7 08-04-2020 01:06 PM
Issues With Presonus Studio Channel..Please Help!!! mccox1004 Third Party Interfaces 1 04-07-2015 07:23 AM
the digi 02r pres or the a presonus 1 channel pre sbag Tips & Tricks 5 10-24-2007 10:39 AM
What are some good 4 or 8 channel mic preamps? (Not Presonus/focusrite etc.) El CaCa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 22 08-03-2003 07:42 AM
Presonus digimax 8 channel mic pre w/001 jjb715 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-05-2001 09:20 PM
