Just upgraded to MBA M2 - PT no longer working
I'll preface my situation with the fact, that I was half expecting to run into issues...So now I'm hoping for a solution!!
For the last few years, I've been using a PT 2018.4 perpetual license. I know it's an old version, but I'm not a power user, I don't need all the newest features, and I find this version offers all the main features I need. PT was happily running on my 2019 MBA with Catalina. But this week I've upgraded to a new MBA M2 running Monterey, and this version of PT installed fine, but won't boot up. I don't even get an error message as to what the issue is. So I've been trying to find out what is the latest OSX that supported 2018.4, and whether I can reinstall that older OSX on this new machine, or I'm just going to have to pay to upgrade to a newer version of PT? Any thoughts or experiences appreciated Mike |
Re: Just upgraded to MBA M2 - PT no longer working
Without actually looking up if PT 2018.4 is compatible with Monterey ... I will mention that you may need to check System Prefs >> Security & Privacy while you are installing PT. Sometimes you need to give an installer permission there manually. It will tell you it has blocked something and you can click "install anyway" or something like that. The thing is, that message and option does not hang around for long so you need to check it while you are installing.
Worth a try. |
Don't think it's related to security preferences, as no errors came up during the installation. Plus I've since located a document on Avid site that says High Sierra was the last OSX that 2018.4 supported - https://avid.secure.force.com/pkb/ar...4-Release-Info
I'm also now considering setting up an older OSX on a bootable drive, and just using that when working on PT projects. That way I can keep the latest OSX on the MBA. |
Usually Avid will not test, above in your case High Sierra, once they move on. Most people will stretch an OS X above like to Mojave. But you might be out of luck trying Monterey with a 4 year build of Pro Tools. Seems 3 is the number. 2022.7 is tested to Catalina. When we move ahead it will be Ventura, Monterey and Big Sur. Members of DUC will test and push the boundaries, one way or another and results will very. Your idea of a OS X partition that works with your Pro Tools is probably a good choice. Changing hardware probably didn’t help either.
PT 2022.12 studio, Cubase 12 Pro, 12 Core Mac Pro 6,1 96GB OS X 12.6.6, Mac Mini i7 QC 16GB, Digico Soundgrid DLI, Revive Audio 96IO & 192 DBox & 2BussLT for summing, Waves, SoundToys and a pile of other plugins. NI Maschine/Komplete Ultimate 12 and many many, too many Kontakt Libraries. https://www.youtube.com/channel/UCmT..._as=subscriber Last edited by LoudBassTone; 08-06-2022 at 05:47 AM. Reason: more |
Historically, Apple Mac's cannot run any OS version older than the one that was current when the machine was introduced. In this case your new MBA can only run Monterey and higher, so you idea of having a bootable drive with an older OS won't work...Unless you meant to run on your older MBA.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Indeed, I think your only option for the MBA M2 is the newest version of Pro Tools. Apple never cares about backward compatibility, so every time they update OSX or hardware, it usually breaks everything(1 more reason I run a PC)
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
Your old Catalina is not even compiled for Apple silicon macs, so it could never run, let alone any typical minimum macOS version support issues.
You need to get Pro Tools upgraded. If your perpetual update/support programme has expired you need to purchase a support reinstatement/upgrade. And you also want to be doing this because the rate of Pro Tools bug/compatibility with Mac releases is very high and you may need those future releases, you also will want to get the future release of Pro Tools with Apple native silicon support. Do not screw up and buy the wrong product, be sure you read about and understand the difference between buying a subscription, a support/update plan renewal, or a support/update plan reinstatement/upgrade. If you do not understand this then call up a sales rep at a large Avid dealer (like Vintage King) and talk to them live about exactly what you have and your options. |
Thanks for all the feedback and advice.
I found a USB stick lying around with an old OSX installed (I think Maverick) and you're right, the new M2 MBA won't load/run it. I did have success with this on the 2018 MBA, which I'm guessing is because those OSXs supported the Intel chip, and this machine is now Apple silicon. Ironically I did get an email from Avid last week, offering a discount on upgrading to the latest version. It does say I'd be upgrading to a perpetual license plus get 12 months of new features and support, but like someone already mentioned I'd better read the fine print!... |
Yes read up, but that discount/promo *is* what you want to take.
PTHD 10 no longer working on 2009 Mac Pro upgraded to 5,1 firmware | mindbreathe | Pro Tools 10 | 1 | 03-08-2018 05:39 AM |
Pt 11 mac no longer working right | terryrocks | Pro Tools 11 | 3 | 04-12-2015 12:01 AM |
Upgraded from PT 10.3.7 to 10.3.8 and Eleven is no longer authorized | rofa | Pro Tools 10 | 2 | 01-28-2014 11:13 AM |
alt-tab no longer working | xian$ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-23-2005 10:08 AM |
002 not working when i upgraded from 5.3.2 | jayquik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-06-2003 10:09 AM |
