sudden change in session sample rate
Somehow my session in 6.4.1 changed it's sample rate. Earlier versions were at 48K. But in a later save it was somehow changed to 44.1.
In 6.4.1, I see no way to change the sample rate in the session setup window. I see in the manual some reference to a "pop up window" in the playback engine, but the window does not pop up for me and I see no way to change the session's sample rate in any other menu. I seem to recall that in PT 5.1.3 I could change session sample rate from the session setup window. In 6.4.1 this feature is now greyed out. How can I change the sample rate in a session back to what it's supposed to be?? Thank you. sincerely c-post
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!" |
Re: sudden change in session sample rate
Yeah, I had this problem with some sessions in 6.4.1 too. The only solution is to open a new session with thew correct sample rate and import tracks.
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
Can I change the sample rate of an existing session? (PT9) | bicasaur | macOS | 2 | 07-28-2013 01:40 PM |
Sample rate issue, Session was set at 44.1, forgot to change preamp to 44.1, | goodfriendelectric | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-30-2010 10:19 PM |
Can I change the sample rate of my session? Help! | Allbaldo | Pro Tools TDM Systems (Mac) | 9 | 05-09-2006 01:05 PM |
Sample rate change during session? | JonMitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-02-2005 10:47 AM |
Can't change Sample Rate in session anymore? | Transducr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-21-2004 07:17 AM |
