Old 02-24-2017, 05:32 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
Default Structure Free not showing in 12.7.1
I seem to remember that this happened before, but cannot find that workaround anymore.
Re-installed the AIR VI Bundle again and for sure there is a Structure.aaxplugin in my folder, but it doesn't show up. Xpand, Boom and all other friends are there...
Any ideas?
Arno Peeters
Tape TV Productions
Old 02-24-2017, 07:26 AM
unkJE's Avatar
unkJE unkJE is offline
Default Re: Structure Free not showing in 12.7.1
First thing – save your existing Structure/Structure Free User Presets to somewhere retrievable, to be returned after you’ve installed your correct version of Structure.
You can have either Structure Free or Structure in Pro Tools 12 – but not both together.
If you own the full version of Structure, you don’t need Structure Free.
If you don’t own the full version of Structure, uninstall it and remove the plug-ins.
Next time you launch Pro Tools, Structure Free (included in Pro Tools 12) will be added.
For those who own the full version of Structure, the procedure is to install Pro Tools, delete Structure Free and its Content, then install the full version of Structure.
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 02-28-2017, 04:30 AM
As I come to understand it: there *is* no Structure Free for Pro Tools 12.x?
Arno Peeters
Tape TV Productions
Old 02-28-2017, 12:28 PM
You are incorrect. If for some reason it doesn't install on PT launch, go to Applications folder and double-click on PT app, show package content, copy the .aaxplugin from that plugin folder to the /Library plugin folder
Old 03-01-2017, 06:57 AM
Thanks. Unfortunately I cannot find either structure or structure free inside PT's package content?!
Arno Peeters
Tape TV Productions
Old 03-01-2017, 09:30 AM
My bad, it must then be in the AIR installer that is separate from PT installer. You should find it from your Avid Account
Old 03-01-2017, 12:17 PM
unkJE's Avatar
.... it must then be in the AIR installer that is separate from PT installer. You should find it from your Avid Account
That's correct.
For Structure Free, look in your Avid Account under “Pro Tools Plug-ins” for AIR Instruments Bundle 12.0 Installer.
It’s grouped with AIR Effects Bundle 12.0 Installer and Xpand II 12.0 Installer.
Old 03-02-2017, 04:51 AM
Couldn't extract the Structure Free AAX.pkg, so simply installed the whole shebang again and low and behold: Structure Free is back!
Arno Peeters
Tape TV Productions
Old 03-29-2023, 09:37 AM
kirkus8 kirkus8 is offline
In Your AVID Link, Look for the Air instruments Bundle 2018.10 it's in that update/download.
Old 03-29-2023, 10:24 AM
1. you are replying to a post from way back in 2017.
2. (for other users) this advice won't work for anybody running native on Apple Silicon as Structure Free has been abandoned and is not supported there.
3. if you are relying on Avid Link for anything it is likely part of the problem you are having
Structure Free unable to load homemade files from Structure 1.0 tuchel Virtual Instruments 0 04-26-2013 09:10 AM
When I loaded Structure from VIRT pack, Structure Free menu still there. dl0banter Virtual Instruments 2 06-12-2011 02:23 AM
Structure Showing up as Structure Free? Roper Band Virtual Instruments 4 06-02-2010 02:43 PM
Structure Full showing as Structure le Dj-Ike Virtual Instruments 8 04-15-2010 03:09 PM
Structure Free's not showing up as an insert JaRu Virtual Instruments 1 09-20-2007 03:19 PM
