Set Selected Track to Input
I am a little frustrated trying to find an easy way to set a track to input via my Dock and S3. The best I have found so far is inside the Control ap on the "mixer" and "tracks" page, but that's a bit of a bother since it can require a few button pushes to get to it and the target area is small. A modifier key assigned to the "Record" button on either surface would help. Or, hold the "select" button and toggle through options with the "record" button.
But maybe I am missing something? Best...H |
Re: Set Selected Track to Input
I found "Set record tracks to input" under the "Tracks" options in Eucon. This is an incomplete solution, since I still can't select input on a track without having it in record, but it's way better than nothing.
I've assigned this to the touch strip on the S3. Any other solutions are welcomed. Best...H |
Sadly there is no Input Enable mode (or button)
This has been asked for a lot. The Control app options that you've found are the only ones available for now.
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Thanks BScout!
Best...H |
In the next release you can also do this from the Channel page too (along with Solo, Mute and Record). The Shift modifier is already used on the surface Rec button for Automation mode. Maybe on the S1 the unused X button could be used.
Duplicate Track = full window of track selected... Anyone else. | Shifted Music | Pro Tools 11 | 6 | 11-25-2014 10:40 PM |
Auto-bank to selected track does auto-nudge to selected track | goran m | Artist Series | 0 | 10-16-2013 08:54 PM |
BUG? selecting midi track arms record for selected track | browniespeaks | Windows | 40 | 06-10-2013 11:41 AM |
Bounces selected track but shows remaining time of longest track | mwsmith007 | Tips & Tricks | 5 | 01-06-2013 07:21 AM |
MIDI Input Problem - Selected Track vs Record Enabled | salmonsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-28-2008 07:42 AM |
