Spinning Wheel of Death when Changing Track Output
I've had this problem across several versions of PT. Sometimes, when I try to change the output of a track, I get a spinning beachball that never resolves. This happens right when I click on the output path selector on the track, looking at the edit window. It also causes one of my external hard-drives to spin up, which makes no sense since that drive is only for manual drag/drop backup. With all external drives unmounted, the problem still happens. Everytime, I have to force-quit and open a session backup file.
Trashed preferences has not resolved. Any help would be greatly appreciated. Mac Studio 2022 M1 128GB RAM Monterey 12.4 PT Ultimate 2022.10.0 UAD Apollo X16 TB3 and Apollo 8 TB2 Last edited by ChrisL; 01-26-2023 at 07:00 AM. |
Re: Crash when Changing Track Output
Hey Chris,
Found this post from having a similar issue, would try and change a group of tracks' outputs to go into a routing folder and near-instantly get a beachball crash (Monterey 12.6.2, PT Studio 2022.12, Mac Studio M1 Max). Mine however was happening on the Mix window when changing outputs, selecting them on the Edit window worked first time. It does seem to happen more when working with template folders/tracks imported from another session. |
Very interesting that we have similar system specs with this problem. upgrading to 2022.12 has seem to have made it worse. Unfortunately I can't get a crash report with a spinning wheel of death. Does yours stop and start spinning repeatedly? I am now getting random spinning wheels, even without changing I/O. Sometimes, it happens 1-2 times per hour and I have to force quit/restart protools. Except NOW, my most recent backup gets the "corrupted magicID" error(that I've never gotten before) and I have to restore from an earlier backup.
I do indeed work from a template with folders, maybe it is time to get rid of the folders for now and see if that helps. I will report back. Last edited by ChrisL; 01-26-2023 at 06:59 AM. |
Unfortunately, getting completely rid of routing folders hasn't fixed the problem. If anyone else has any solutions to try, I welcome it! Random spinning wheel's of death that never resolve are brutal when cutting vocals.
2022.9 Crash when changing track to Playlists view | njrsound | Pro Tools | 3 | 09-14-2023 07:42 AM |
Bug: Frozen Crash When Changing HW Device | ashmatthews | Pro Tools | 11 | 06-17-2022 11:54 AM |
PT12 Track Output Busses Changing | JamesDrake | Pro Tools 12 | 1 | 12-08-2015 04:11 PM |
Changing track input/output assignments corrupts session files, causing PT to crash. | horribleheaven | Pro Tools M-Powered (Win) | 1 | 07-08-2010 11:47 AM |
Crash when changing playlists? Mix to HD? HELP! | flymax | Pro Tools TDM Systems (Mac) | 1 | 01-20-2004 10:47 PM |
