Hi, I just downloaded Protools (30 day trial) and I'm unable to fully boot the application. I've tried three times, and each time it crashes while scanning my plugins. I am running a 2019 Macbook Pro on Catalina 10.15.6. I have some old plugins on this computer, but I don't know how to figure out which one is causing the crash. I'd like to attach my crash logs to this post (as customer support advised). What is the best way to do that? The file format is not accepted as an attachment to this post. Thanks in advance!
Customer Service is for the Avid Support Center, not here.
Crashing while scanning plugins is not unusual. Go to here /Library/Application Support/Avid/Audio/Plug-Ins move ALL the plugins from there to /Library/Application Support/Avid/Audio/Plug-Ins (Unused) (If this folder does not exist, create it: "Plug-Ins (Unused)") Then open Pro Tools. Then close Pro Tools. Move group by group plugins back from the Unused to the regular folder, opening and closing Pro Tools each time. If you have a crash after you moved a group, move that group back out again as something in that is bad (You can create a third folder "Plugin-Ins Check" to hold the possibly bad plugins) You'll find the bad plugins faster than you'd think this way. And then make sure your plugins are up-to-date.
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD Omni • S1 x 2, FireHD x 2, Dock, iPad • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB Pro Tools Ult 2022.12, RME BBF Pro • Mac Mini 14,12 - 12 core - macOS 13.2 • RAM 32GB, SSD 4TB, GPU 19 core |
If you already have a bunch of plugins existing from previous work with other DAWs, since your system is getting on the older side, the new version of PT, while it should be okay, a bunch of those older plugins are very likely to be potential problems as BScout indicates.
You might be able to continue to use the VST and AU of those plugins in other DAWs, but the AAX plugin folder that BScout points out might be so old they just aren't compatible anymore. (Even when you were not using PT yet, plugin installers might have been putting plugins into this directory path, because they might be usable by many and were packaged with those installers, but written with older versions of PT in mind.) If you leave just those bad plugins in the Unused folder, everything else might be working okay! Good luck.
___ >> me: nednednerB // ||main gig: editing audio & testing software / 2nd gig: music software tutoring // ||software: Monterey 12.5.1 | PT Studio 2022.10 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB // ||devices: Focusrite Clarett 2Pre | some AT condenser mics | SM58 | Ableton Push 2 | 32" 4k LG secondary display // ||automation: SoundFlow | Keyboard Maestro | SteerMouse // |
Couple of thoughts:
1-how are you opening Pro Tools or sessions? If you have PT closed and go directly to a session and open that(expecting PT to open, followed by the session), try opening Pro Tools only(no session) and let us know if that crashes. Opening PT first is preferred. 2-if you can open PT, but opening a session causes the crash, hold down the SHIFT key while opening the session. This will make all plugins inactive. If this allows the session to open, then you have a rogue plugin. Move all 3rd party plugins out of the Plugins folder and then put some back and test until you figure out the culprit.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Thanks for all the advice! I'll give this a try and hopefully won't have to ask for more help.
Don't be surprised if after a launch of PT that the plugin folder suddenly has plugins in it, even if you're shure you emptied it; this is a function in PT. All the standard Avid plugins are stored in the PT application, and PT reinstalls them automatically at launch, if they are not present.
I like to use color labels when managing or troubleshooting the plugins folder. All the standard plugins have a red label, so they are easy to spot. I might have green label on 'tested and OK' plugins, and so on. And I sort the folder by labels. Also useful to know: It's totally OK to create sub-folders. Folders for each manufacturer, for sets of plugins etc.
Life-long audio enthusiast and small studio owner. Retired. – Ben's Blog Mac Mini M1, 16GB RAM. MacOS 11.6.8. PT 2020.12.1. EuCon 2022.12.0.81 Topping D50 DAC, Dynaudio BM6p, 2 x Artist Mix, SSL UC1, EuControl on iPad. |
2020.12 crash scanning Ethernet port | dogsface | Pro Tools 2020 | 4 | 02-16-2021 07:49 PM |
PT 2020.3 crash on launch while scanning plugs | mj94122 | Pro Tools 2020 | 4 | 05-12-2020 07:03 AM |
Plugins not scanning nicely | Neale | Pro Tools 2019 | 53 | 10-03-2019 05:56 PM |
scanning plugins | bongo_x | Pro Tools 10 | 1 | 03-29-2016 08:50 PM |
10.3.10 ran out of memory scanning plugins | crizdee | Pro Tools 10 | 29 | 02-08-2015 12:24 PM |
