I've been reading through the EuControl surfaces documentation. I have an S1 and a Dock. I am planning on adding a second S1 shortly. The documentation says: The order (top-to-bottom) that surfaces are listed in My Surfaces determines the order of fader strips (1–n, left-to-right). For example, if you add two S1s the top-most S1 will default to tracks 1–8 and the lower S1 to tracks 9–16 Since I only have a single S1 and Dock at this time, does the order matter at all? I did try moving the order around but other than the screen refreshing I didn't see any functional change. Please let me know what you think. Best... |
Put the dock at the bottom. I have found if the Dock is at the top, you'll get some weird banking/nudging of the faders. (It's been awhile but I would get things like the next track instead of the attentioned track on the dock fader or a duplicate fader on the dock fader instead of the attentioned track.)
That doesn't happen with the Dock at the bottom (after all your S1) (The position of the tablet on the Dock doesn't matter though)
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD Omni • S1 x 2, FireHD x 2, Dock, iPad • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB Pro Tools Ult 2022.12, RME BBF Pro • Mac Mini 14,12 - 12 core - macOS 13.2 • RAM 32GB, SSD 4TB, GPU 19 core |
Hi and thanks for the response. I'm still learning the ins and outs; purchased these last month. Did you get a chance to see the screen shot I attached? It shows my current setup with the Dock at the Bottom. Is this correct? Once I get the second S1 how should the order look?
Thanks again |
Yes, saw your screenshot and that’s good. If/when you get your second S1 put the one on the left at the top and the one as the right (whether side-by-side or the dock in between the two S1 units) second.
Perfect!
Thanks for the clarification. Rick |
Avid S1 suddenly disappeared from My Surfaces (EuControl) | OpiZA | Avid S1, S3, Dock and Control App | 3 | 10-08-2021 11:24 AM |
1st order to 3rd order Ambisonic conversion issue | mrataj | macOS | 0 | 08-16-2021 11:59 AM |
Missing VCA's in EuControl Surfaces | ThomasHQ | Avid S1, S3, Dock and Control App | 16 | 04-03-2019 01:26 PM |
Control Surfaces | Fooks | General Discussion | 0 | 05-21-2012 11:35 AM |
Order region list in the order the regions are on a track | Wesselink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-30-2009 07:53 PM |
