#21
![]() Quote:
Either way, if true, they should update their diagrams/KB on the situation to define this. I mean the second link clearly says "that can be achieved utilizing Carbon Pre's ADAT I/O" and then proceeds to have the Carbon with 2 Carbon Pres as the first line.
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD Omni • S1 x 2, FireHD x 2, Dock, iPad • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB Pro Tools Ult 2022.12, RME BBF Pro • Mac Mini 14,12 - 12 core - macOS 13.2 • RAM 32GB, SSD 4TB, GPU 19 core |
#22
I'm also going to muse on latency issues due to the variable configurations. Will Pro Tools be aware of any of them (possibly by setting them up as mic pres in Peripherals + I/O setup mic pres? Only place I can think it could be defined inside Pro Tools.) It'd be interesting if the latest (or future) Pro Tools had a defined "Carbon Pre" spec to adjust for this.
#23
![]() Quote:
Do you have any plugins on the tracks? I had an issue with BX Console making things really slow when turning on and off DSP mode.
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.4 Monterey -32 gigs Ram - Carbon - Protools 2022.6 Ultimate |
#24
This may be totally off the wall, but here goes:
First I was initially very interested in the Carbon|Pre. If the pre amps are the same as in Carbon, they will sound great. The controllability and recall from within the Pro Tools session is a major plus. No DSP in PRE is a bummer. My question though; So, why wouldn't/couldn't a person use the AUX I/O feature with say a Focusrite 8PRE or similar? That's expanding your mic pres by 8, or whatever the interface has. (Honestly have not had time to test this out. Corn picker's fever this time of year you know) Other than the control/recall, if you're OK with the other interface's pre amps, what's the advantage of Corbon|Pre? I'm still interested in the unit, but....asking for a friend. ![]()
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob Squaw Creek Road Studio Pro Tools Ultimate (2022.9)| Pro Tools Carbon | Sibelius Ultimate (2022.9) | 3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS 12.6 | Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X | Lenovo i7 ThinkPad | Win 7 Professional | Avid 003 + Rack | |
#25
![]() Quote:
It's a pain because I like tracking everything with bx_console but it's effectively unuseable as it is. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Monterey 12.6.3, Pro Tools 2022.12, Carbon. |
#26
Hey all!
I'm at AES with Carbon Pre & MBox. When I am back at the office I'll go through the thread and answer as many questions as I can. In an extremely quick summary...
There are two great vids at the bottom of the Carbon Pre page... give em a look and let me know what else you are interested in... https://www.avid.com/products/pro-to...bon/carbon-pre m
Mark Corbin Avid Sr Product Manager Professional Audio Systems For immediate assistance: Pro Tools & Eucon Surfaces - +1 888-456-3444 Venue Support - +1 978-275-2557 Find out how to create, manage, and edit cases online now HERE It's fast, easy, and effective! |
#27
![]() Quote:
Thats an interesting question about the new Aux I/O feature in PT 2022.9 I am guessing (and only guessing at this point) besides having the Carbon pre's and converters is that by connecting via ABV Ethernet you can have 24 input channels running above 48k which is the limit for 16 additional channels via ADAT into Carbon Now whether or not someone would need that is a different discussion.
System : Avid Carbon interface , PT Ultimate 2022.10 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Monterey 12.5.1 "Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein Enjoy the Journey.... Kev... |
#28
![]() Quote:
So if your session is running at 96K so is the Carbon and so you set your second interface to run the same because you are not inputting into the Carbon, but along with it. I dunno
#29
![]() Quote:
And I am unclear as to what you mean Quote:
#30
Hey Mark,
Does it actually expand the total I/O in Carbon with Pro Tools to 32+TB by adding Carbon Pre, or does it replace existing I/O with preamps, but not add additional total number of inputs in PT? In the video it *LOOKS* like it's adding 8 additional inputs for B and another 8 inputs for C in the I/O matrix view, but the documentation makes it seem like it does not, as does some of the verbiage in the video. The documentation specifically states "Maximum I/O expansion Pro Tools | Carbon supports up to two Pro Tools | Carbon Pre interfaces for up to 24 mic/line inputs and 24 line outputs", which is a bit ambiguous. In PT will it effectively be 8 additional Carbon inputs with normal AAX DSP enabled monitoring capabilities (using Carbon's DSP, of course), or is it expanding more like using the new Aux I/O? Quote:
Pro tools Carbon and ADAT | Rob Hannon | Pro Tools | Carbon | 6 | 09-26-2021 08:04 PM |
Pro Tools Carbon FAQ | Avid | Pro Tools | Carbon | 0 | 09-19-2021 04:07 PM |
Pro Tools Carbon with Standard and HDX? | atticmike | Pro Tools | Carbon | 12 | 12-03-2020 05:24 PM |
Pro Tools | Carbon | Avid | Technical Alerts | 0 | 11-12-2020 04:14 PM |
